Question about Nintendo Wii Console
Cd stuck my wii sport cd will not eject from the console, i have powered down the unit but still won't eject thx
  • 1 more comment
  • skbat Nov 18, 2007
    Tried the solution suggested but still can't get Wii sports to eject - any other suggestions?
  • linkin park Aug 13, 2008
    my brawl disk wont come out but i called nintendo and they said theyed repair it
  • joe_naco Dec 25, 2008
    we were going to change from one disk to another and it got stuck and i am trying to see how to fix it but i dont have the tools...
    Problem Solver:
  • 9 Answers
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Posted on Jun 07, 2008
    Problem Solver:
  • 18 Answers
Try slightly sticking the edge of another CD in it to activate the disc sensor, then try ejecting it again. Try both the Wii's button and the Wiimote's button.
I hope this helps =D
Posted on Oct 28, 2007
Try playing iwth if for a little while to get if warmed up an then, try ejecting it. Worked for me. :) :) :)
Posted on Dec 26, 2007
SOURCE:
Disc will not eject
Turn the Wii off and on again after about 20 seconds. Press the eject button again.
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on.
Hold down the eject button for 5 to 10 seconds
Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out.
Call Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty.
Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds.
Aug 22, 2010 | Nintendo Wii Console
Will not eject disk
Is your eject button broken? Does it click when you punch it, or goes in like the button on the board is broken?
It is either this or there is something jammed inside your system.
Video: How to open Wii Console
Check inside your drive and remove anything stuck in there causing the drive to not function correctly when ejecting.
Hope I helped!
Take care
May 09, 2010 | Nintendo Wii Console
Wii Fit disk will not eject
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
aqwtr-101
Jun 13, 2009 | Nintendo Wii Console
Wii won't pull disc in
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.................................
Feb 28, 2009 | Nintendo Wii Console
Game stuck in console
Try thees steps
Turn the Wii.html#" target=_blank itxtdid="7750962">Wii off and on again after about 20 seconds. Press the eject button again. 2
Unplug the Wii's AC power supply if Step 1 doesn't work. Wait 1 to 2 minutes, and trying to eject the disc again after turning the Wii back on. Hold down the eject button for 5 to 10 seconds. 4Try ejecting the disc with the Wii at different angles. If you hold the Wii upside down, it may help the disc fall out. 5Call Wii.html#" target=_blank itxtdid="7751052">Nintendo and send the Wii back if non of these steps work. In most cases, a disc stuck in the Wii should be covered by warranty. Nintendo says to see if power light was coming on, AC adapter reset. unplug from both ends for 90 seconds.Hold eject button for five or 10 seconds Good Luck
Jan 23, 2009 | Nintendo Wii Console
Wii eject button will not work
Mar 17, 2008 | Nintendo Wii Console
Nintendo wii system gamecube game is stuck inside ,everything else still works
it's the ejectijon button cause i have the same problem but with a wii disc
Feb 09, 2008 | Nintendo Wii Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Can't get Wii sports disk to eject
From the official Nintendo site:
"The Wii console will need to be repaired. Because this type of damage is not covered under Nintendo's warranty, there will be a charge for the repair. Please call 1-800-255-3700 to discuss available options."
Nov 18, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
2,759 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
