Internet sharing I have a dell with windows XP that I have a wireless ATT card for the internet and I would like to be able to access the internet with my other dell that is running windows Vista but can't figure out how
    Brigadier General:
  • 6,966 Answers
Hi, Could be done. On the Dell XP - 1. Activate your Internet Connection Sharing. Go to Control Panel, Click on Network Connections, right click on your Local Area Connection, Properties, Advanced tab, check Allow other network users to connect through this computer's internet connection. In Home networking connection, choose "Local Area Connection", OK; 2. Back to General settings, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.1, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." You have to connect the DellXP with the DellVista using a crossover networking cable. On the Dell Vista- 1. In your Network Connections, right click on your Local Area Connection, Properties, click on Internet Protocol (TCP/IP), click on Properties, tick Use the following IP address: IP address 192.168.0.2, Subnet mask 255.255.255.0, Default gateway 192.168.0.1, if you know ITT DNS use them otherwise tick "Obtain DNS server address automatically." The above method will also work with peer to peer wireless networking. It might also facilitate connection if you enable auto-detect proxy settings in your browser. There are other methods. This is also better explained at Microsoft support Hope this be of help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Posted on Sep 30, 2007
SOURCE:
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
Where is switch on dell latitude e6400 to enable wireless internet access?
hi
go to this link, review
What You Need to Establish a WLAN Connection http://support.dell.com/support/edocs/systems/ins6400/en/om/network.htm#wp1052373
  1. Click the Start button, point to Settings, and then click Control Panel.
  2. Double-click Network Connections.
  3. Right-click the Wireless Network Connection icon, and then click View Available Wireless Networks.
If the Choose a wireless network window states Windows cannot configure this connection, the wireless network card's configuration utility is managing the wireless network card.
If the Choose a wireless network window states Click an item in the list below to connect to a wireless network in range or to get more information, the Windows XP operating system is managing the wireless network card.
Dec 01, 2010 | Dell Latitude E6400 Notebook
What is the specification of windows Xp?
Windows XP Professional System Requirements Published: August 24, 2001 Here's What You Need to Use Windows XP Professional • PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
arrow_px_up.gifTop of page Additional Items or Services Required to Use Certain Windows XP Features • For Internet access:
• Some Internet functionality may require Internet access, a Microsoft .NET Passport account, and payment of a separate fee to a service provider; local and/or long-distance telephone toll charges may apply
• 14.4 kilobits per second (Kbps) or higher-speed modem
For networking:
• Network adapter appropriate for the type of local-area, wide-area, wireless, or home network you wish to connect to, and access to an appropriate network infrastructure; access to third-party networks may require additional charges
For instant messaging, voice and videoconferencing, and application sharing, both parties need:
• Microsoft .NET Passport account and Internet access or Microsoft Exchange 2000 Server instant messaging account and network access (some configurations may require download of additional components)
For voice and videoconferencing, both parties also need:
• 33.6 Kbps or higher-speed modem, or a network connection
• Microphone and sound card with speakers or headset
For videoconferencing, both parties also need:
• Video conferencing camera
• Windows XP
For application sharing, both parties also need:
• Windows XP
For remote assistance:
• Both parties must be running Windows XP and be connected by a network
For remote desktop:
• A Windows 95 or later-based computer, and the two machines must be connected by a network
For sound:
• Sound card and speakers or headphones
For DVD video playback:
• DVD drive and DVD decoder card or DVD decoder software
• 8 MB of video RAM
For Windows Movie Maker:
• Video capture feature requires appropriate digital or analog video capture device
• 400 MHz or higher processor for digital video camera capture
Oct 11, 2010 | Microsoft Windows XP Professional
How do i share internet with others when I suscribe to internet I was told when I signed up with Tmo that windows settings allow you to share connection.
Windows Settings allow you to share your internet connections providing you have 2 network connections IE: 2 X Ethernet cards 1 X Ethernet Card 1 X Wireless Card. Then on the computer you want to "share" the internet on click on control panel /Network then right click on the card that is connected to the internet you want to share. got to Properties then advance . Tick the box "Allow network users to connect through this computers internet connection" Reboot that PC and any pc connected to that PC either by network cable or wireless will be able to use the internet
Jul 24, 2010 | Dell Inspiron Mini 10 Notebook
How do I know if my wireless card is working?
Go some where that you know there is an active and working Wireless Access Point. The closest Starbucks will show up as Att-Wifi and then when you go online you get the Att login page. The internet won't work unless you have a login. You could go to McDonalds now, since their wifi is free now.
Dec 20, 2009 | Dell Inspiron E1505 Notebook
Network Vista Wireless Laptop to XP Desktop & Print Documents
On the desktop machine - go to the printers folder, right click the icon for the Laserjet and choose sharing (enable print sharing). You should be able to name the printer and make it accessible to anyone within the workgroup. If needed you can run the network setup wizard to change the workgroup names on both machines.
On the laptop go to add new printer and choose network printer, you should be able to browse to the desktop machine by name and choose the Laserjet as a printer (whether you want it to be the default is up to you). The laptop will download and install the drivers from the desktop pc to the laptop and set the correct network path automatically.
It goes without saying that the desktop machine must be on in order to print from the laptop in this scenario.
Feb 21, 2009 | Dell Inspiron 1525 Notebook
Can not connect to internet using wireless
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Jan 16, 2009 | Dell Inspiron 1200 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Server cannot see wireless workgroup machines but shares Internet
Disable any firewalls on the machine like Windows firewall or any other firewall like Norton, McAfe, ZoneAlarm and something like that. Or if you have firewall policies or access rules, you must enable the sharing there.
Oct 31, 2008 | Belkin Computers & Internet
Open Questions:
BITDEFENDER TeCH SuPpoRt PhoNe /[email protected]/18OO8\O31\O69/[email protected]/ number ms ouoi This BITDEFENDER USA phone number is ranked #2 out of 2 because 7,728 BITDEFENDER USA customers tried our tools and information and gave us feedback a fter they called. The reason customers call # I:8OO:,:8O31069 is to reach the BITDEFENDER USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, BITDEFENDER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BITDEFENDER USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact BITDEFENDER USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BITDEFENDER USA Calling BITDEFENDER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BITDEFENDER USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BITDEFENDER USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BITDEFENDER USA's phone numbers against each other. Contacting BITDEFENDER USA in General While I8OO8O31O69 is BITDEFENDER USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BITDEFENDER USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BITDEFENDER USA.
Oct 16, 2019 | BitDefender Computers & Internet
AOL MAil TecH SuPPoRt {1^855^536^5666}#[email protected] PHoNe NuMbER SUPPORT NUMBER This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 16, 2019 | AOL Computers & Internet
Computers & Internet Logo
183 people viewed this question
Ekse
Alun Cox
