PHILPS 29PT449A, FAULTY REMOTE, PROGRAMMING HASSLE
REMOTE IS FAULTY AND TRYIN TO PROGRAMME CHANNELS WITHOUT REMOTE, ANY HELP. CAN GET TOT THE INSTALL SELECTION SCREEN BUT NOT ABLE TO FIGURE OUT HOW TO SCROLL AN SELECT WITHOUT REMOTE
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Regarding tv remotes please check web site for proper help. www.remotes.com give model name in search. hope this will help.
Posted on Oct 02, 2007
CHANGE CHANNEL TO AV/SCART ON A GOODMANS TVC 1400 WITHOUT THE REMOTE CONTROL , ONLY RUNS THROUGH 7 CHANNELS
Not familiar with this, but see if there is another button on front or top or behind a cover marked AV or source, if so then that will select the channel you want.
Sep 16, 2014 | Televison & Video
How can I get my TV out of now scanning mode?
Without better information, I can't be of much help. To me it sounds like it's searching for channels using the Auto Programming feature. This should stop on it's own once it has scanned for all the available channels in your area.
Oct 05, 2012 | Innovage Jumbo Remote Control
Can you change channels on tv's without remote
Hello
If your tV has a Menu Button and channel up-down, programme up-down button at tis front control panel, you can change channels and other inputs using these buttons. You haven't give any details of your tV, its Brand Name, Model Number etc, so I can give you this much detalils only to you.
Nov 25, 2011 | Televison & Video
Goodmorning, bought a zenith tv didn't get the remote. Wonndering how i can programme it using just the buttons on the tv. How do i get the menus up. it only catches threes channels as of now.
Hello
There are two types Zenith TVs. One type will have "Menu" button on its front panel and other will not. If your Zenith is the first type, you can programme it without a remote control. If it is the second type, you must have a remote control hanset to programme it.
Programming method
First connect the TVs antenna socket at its back with external antenna or cable.
* With the remote control in hand, press the POWER key to
turn on the Presentation TV.
** Press MENU repeatedly until the Setup menu appears.
*** Using the Up/Down arrow on the remote control, highlight
Auto Program on the screen
**** Press the Right or Left arrow to go to the Auto Program
menu.
***** Using the Up/Down arrow, choose either Cable TV or Off-
Air Antenna on the screen.
****** Press the Right or Left arrow to begin the Channel Search.
******* Press ENTER when the channel search is done.
Note: Auto Program finds channels being received by the TV
tuner
Cable will not work unless you subscribe to a cable service
OK.
Jun 17, 2011 | Zenith H27E35DT 27" TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
How to get to menu without remote
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
Jun 03, 2010 | Panasonic PV-M2089 Combo
Programme tuning tv
You didn't state where you are geographically but I suspect GB.
I would recommend purchasing about any 'universal' remote; they are offered here for under $10 US (another week or two and that will be pocket change for any European).
It would be wise though to check the website of the manufacturer to ensure your set is covered.
Apr 09, 2008 | Televison & Video
Not knowing what TV you're talking about it's hard to say. Can we get a model number on the unit?
Dec 07, 2007 | Televison & Video
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
