Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Wash Motion
Well, the problem has been going on for about 2 days already. first, we put the clothes in. then, when choose heavy duty, put to tap cold/cold water, normal time. then we press start. the machine starts, washes for awhile than after five minutes it stops and displays the code CA and sometimes CI. i know what it means but how do i fix the problem???? please, any answers will be appreciated. thank you for your time.
  • 2 more comments
  • jerortega Apr 27, 2008
    I put my cloths in turned it on it washed for a few minutes then the error code CA came on. I don't know what that means or how to fix it. please help
  • tammypchef Nov 08, 2008
    I have had the same problem off and on for 2 years!!!! My suggestion is GET RID OF IT NOW!!!. We have replaced the motor twice and the water pump 5 times. This machine needs to be recalled. I have had large articles of clothing sucked down into the motor and even the washer bag that holds the small items was sucked down. The last straw was when 2/3s of my king size comforter was pulled under the barrel. I love this washer at first, but as soon as the warrenty expired it has been a nightmare. All I can say is complain to Sears and demand the fix it for free!! They've fixed mine the last 2 times and gave me a gift card for the inconveince, but for the other expenses I have put into this washer, I could have replaced it with 3 by now. I was told today by Lowes that they stopped making these calypso washers(Whirlpool the Kenmore, too) because the design is so flawed and they still won't recall the wothless thing! Take my advice before you lose your shirt....throw it out!!! Good Luck, Tammy, MA
  • Anonymous Jan 05, 2009
    Unbelievable.  I have had this washer for over 6 years.  I like how it cleans clothes but now every other load something gets pulled under the adjitator at the bottom of the washer.  Dryer takes forever to dry clothes always have to hit the bottom one time.  Terrible.
  • Anonymous Jan 25, 2009
    How do you get the LD code off the screen???
  • 447 Answers
Basically its saying that the motor is pulling very high amperes. This could signify a faulty motor, motor controller, or thermal protector, or there could be a mechanical bind in the transmission. i would use a amprobe and check to see how much power is being pulled when the machine starts, and as it is operating if it is 5.55 amps or greater and higher than 20 amps on motor start surge, than the motor controller is correct in saying there is a problem. ------Dont forget to rate my help!!!!!! thanks
Posted on Sep 30, 2007
  • joey  shearer
    joey shearer Oct 01, 2007
    Not helpful??? that really lowers my rankings and it was an accurate diagnosis im sorry there is no magical fix but i feel i was helpful.
  • joey  shearer
    joey shearer Oct 03, 2007
    there is a lot more water in the tub than usual right? Fl means flood level tripped
    your drain pump has either failed (unlikely)
    there is a foreign object in pump impeller or in hoses or in check ball chamber in outer tub
Have had a lot of problems with this costly machine cant get my machine to fill up with water so my clothes wash in a very very small amount of water dont know where to find any water lever either also dont have a manual. HELP im at my wits end with this KENMORE washer
Posted on Apr 26, 2008
Goto consumeraffairs.com and type in Whirlpool calypso washer and cry!!
Posted on Nov 08, 2008
My Kenmore Elite Calypso wont stop washing
What is the model number of your unit?
Nov 22, 2012 | Washing Machines
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Where is the reset switch located on the Calypso
There is no reset.
Simply unplug for 40 minutes to reset the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
I have kenmore elite calypso wash motion washer and there is a flashing light the reads FL what does this mean.
flood lock you need to drain all water from machine and clean out pump somethimg cloggimg pump
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Plastic in drum
REMEMBER IN 4- 6 -8 MINUTES IS YOUR DRAIN AND SPIN CYCLE, PLZ INSPECT PUMP,,, AND SUMP THAT WILL RESOLVE YOUR PROBLEM
Nov 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Grease spots and stains
Yes you can. Remember a front loader has no gearbox so no oil is coming from there? fabric conditioner, washing powder,and oils from our bodys can build up on the tub walls. All it needs is a good flush out. You can use dishwashing powder. Run it through with no clothes in you washing machine on a hot wash or a wash and hold a couple of times to flush it out. NZL
Jan 13, 2007 | Kenmore 20172 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
2,649 people viewed this question
Sal De
Marvin
Marvin
jimorris77
