Question about Toshiba 2405-S221 Notebook
Problem with cover lid on my laptop
When i open this it is very loose and falls off
  • 32 Answers
Obviously a hardware issue, go to a service center.
Posted on Oct 15, 2007
My computer keeps flashing the blue lights on and off,screen blank,not coming on tried to take battery off hold down start button connect to ac nothing happens same problem
Sounds like video card or video cable is faulty or loose. Is screen always blank no matter what you try? Were you getting intermittent screen flickering. There is a ribbon cable that runs from base to lid that sometimes get worn or loose from constant open/close of the lid. Try cranking lid to different positions while trying to boot up. You maybe able to find a video card under one of the covers on bottom. push card all the way inward to make sure it is seated correctly.
Dec 02, 2010 | Computers & Internet
Loose Monitor on a HP Pavilion ZV6233nr Laptop
It seems that some screw that was loose is now totally out of socket. The latch assembly might be disbalanced due to that. To me it doesn't seem to be a broken latch.
Apr 04, 2010 | HP Pavilion zv6233NR Notebook
My dell laptop lcd splashes the OS and then goes dark. It works fine with an external monitor. I have a feeling that there is a loose connection since the top is almost falling off
Think you have answered your own problem here. If the external screen is ok, then the fault lies with the laptop screen.
Solutions..
1.) Remove keyboard top cover (download a "how to" guide if not familar with doing this)
2.) Remove screen bezel
3.) Check the inverter connections (inverter looks like a thin tube)
4.) Check cabling from motherboard to monitor /inverter for signs of fraying, tears, bare wires
5.) Check connections of the cable for damage.
If the above are ok, then you may have a damaged inverter. In any event, i'd look to repairing the damage to the loose lid, as its putting a strain on the wiring
Feb 09, 2010 | Dell Inspiron™ E1505 PC Notebook
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Opening the unit
use a small/jewelers flat head screw driver to separate the silver cover from the rest of it. the rubber buttons will fall out, thats ok. the black backing will not come loose from the actual circuit boards because the FM transmitter antenna is fixed in place under some melted tabs, and then soldered to the board next to the power button. Its usually easiest to unsolder it to get the back off for doing repairs.
May 20, 2008 | Sirius Starmate ST2 Satellite Radio...
Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Nov 30, 2007 | Toshiba Tecra M1 Notebook
Cover of laptop
do you mean the lid falls off has it been broken in half that would cause it to do that? please explain more the cover is the lid Im thinking of??????????
Sep 30, 2007 | Toshiba 2405-S221 Notebook
Toshiba 2405-S221 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
