Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Wacthing sports -Tickers and scores are off screen in HD
Sony KP-51WS510 set. When watching sports in HD mode, the ticker at the bottom of the screen disappears as does the score, or time in the upper corners of the screen. Have gone to the "wide screen" mode on the menu and tried every option and nothing seems to work. Have a Sharp AQUOS where this is not a problem. You seem to only have one HD viewing option on the SONY and it hides the info at the very bottom and top of the screen. Anyone know how to fix???
    Genius:
  • 1,694 Answers
Skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
Posted on Oct 08, 2007
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection kp-51ws510. color alignment
sounds like bad convergence IC---not uncommon on this set-both convergence IC"s need to be replaced and the set adjusted
Aug 07, 2009 | Televison & Video
Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Tim
Dec 22, 2008 | Samsung DLP HL-P5663W 56" TV
Sony KP-51WS510 51 burn in?
You could have leaky capacitors causing this.
Sep 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Top And Bottom Of Screen
If you are useing a cable box or satelight rec. Check the format that you have it adjusted to. If not adjuste the format of the tv. If that does not fix it, it will need to be adjusted by a tech.
Mar 21, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Sony 46" Rear Projection HDTV Bad Picture
Hello, I also have the kp53xbr45 and I am looking for a red bulb, where can I find one at a good price? Thanks
Feb 09, 2008 | Sony KP-53XBR45 53" Rear Projection...
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
