Question about Sewing Machines
Necchi sewing machine
Hi - i have a necchi 537FA and need the bobbin and bobbin holder parts. can you help me. thanks - writzy
  • 47 Answers
Www.ifixmachines.com has lots of parts fitted to your sewing machine for a cheaper price
Posted on Jul 23, 2009
SOURCE:
I have a Necchi model 537FA. When u step on petal, it won't move. Does this machine have 2 BELTS? I only see one. I have oiled before running.
If you don't have any movement or hear the machine attempting to sew, you may have a burnt out pedal.
You should hear a slight hum when pressing on the pedal. If you don't hear a hum, the pedal is probably dead.
These can usually be ordered from the merchant who sold you the machine.
Apr 19, 2016 | Necchi Sewing Machines
My Necchi 537fa is sewing sluggish. Motor spins but needle moves slow. What do I do to fix this?
If your Necchi has an external motor, take the belt off and run it.... is the motor sluggish? If so... that's where you start. motors need to be oiled, typically with oil and grease ports on either end of the motor housing.
If the motor spins up nicely,... you need to clean and oil the rest of the machine. Start underneath if the bottom workings are exposed, oil all the places where metal joins metal. Then do the bobbin and feed dog area... then look along the top and sides for oil parts.. give them a drop or two...Finally, see if you can get into the head where the take up lever and such are... oil the needle bar, presser foot bar, etc.
It's a dirty job... so prepare a good space for your machine. Liquid Wrench will help you free up gunked up and rusty parts. Fine grade steel wool (0000) and Cotton swabs help.
Good luck
Oct 10, 2012 | Necchi 3537 Mechanical Sewing Machine
I have inherited a Necchi 537FA. When I wind a bobbin I loosen the stop motion wheel, but the sewing mecfhanism doesn't disconnect, it still "sews" through the entire bobbin winding procedure! ...
Its been idle for too long and needs a good service. Try and trickle some oil behind the stop motion wheel. But what it actually needs is to have the wheel removed and then apply oil to the shaft. Careful when you start again as oil will fly out from the wheel so mind your drapes and wall decor.
Dec 12, 2010 | Necchi 3537 Mechanical Sewing Machine
I have a Necchi 537FA sewing machine. It sill sew about 39 stitches and then the thread gets caught in the bobbin area and stope sewing. I've cleaned, changed bobbins, spent time trying to fix the...
have you checked to see if the needle is bent-lay the needle on a flat surface & roll the needle over,, if the needle does not roll good -replace
blunt needle-if the needle makes a popping sound when the needle penetrates the fabric,,the needle is blunt-replace
sometimes if the thread comes off the thread take-up lever it can jam the thread in the bobbin area
try rethreading the machine
check to make sure the thread isn't wrapping around the spool pin
check the spool of thread to see if the notch on the spool is catching the top thread
check to see if there's a burr on the bobbin case
I hope one of these suggestions helps you
please rate this using the thumbs in upper right hand corner
Aug 12, 2010 | Necchi 3537 Mechanical Sewing Machine
Need manual for 537FA SERIES sewing machine need
try sites for manuals
sew usa
sewing manual.com
ebay
Jul 22, 2010 | Necchi Sewing Machines
My model is a 537FA. Its an older model and I need the owners manual please
Hi. I found your manual at Relics: http://pages.sewing-machine-manuals.com/173/InventoryPage/1797256/1.html.
I have a Necchi 536 and just love it! Hope you're as happy with yours. . .
Happy Sewing,
Robbie
Mar 16, 2010 | Necchi Sewing Machines
Replacement bulb for a Necchi 537FA
it's the same size as a night light bulb. That's how I replaced mine. You can pick one up at any hardware or dept store.
Oct 31, 2009 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
239 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
