Question about Mitsubishi VS-6041 60" Rear Projection Television
Has been working fine. Would not turn back on, only relay click heard.
Has not shown any previous signs of problems. Just would not turn back on one day. You can hear the power relay click, and can see internally that nothing is powering up. I am more a computer tech, and I am by no means a television tech. It seems to me to be a problem with the power board.
  • 7 more comments
  • rtech Sep 30, 2007 doesn't have a manual for this model, do you know of any other tv manual sites I can check? The power button doesn't light at all, but you can hear the relay click when you push it. The Mitsubishi Electronics web site doesn't provide any support for any tv before 2002. My VS-6041 is a 1996 model. Even so, I could not find a troubleshooting chart for any projection screen on their site, but I am still looking.
  • rtech Oct 02, 2007
    I have tried unpluging and pluging the unt back up after a while several times with no luck. Same symptoms. I have opened up the unit and cleaned up the board with air. I have the unit partially out but still connected. I will start labeling cables shortly so I can get the board out for testing. I just aquired a service manual from and will comment further after I have had a chance to review. Any advise on how to test the flyback transformer and the ic's will be greatly appreciated.
  • rtech Oct 07, 2007
    Sorry, my 3 yr.old has kept me busy. I have checked the fuses with a continuity tester and they are all fine. Power is getting from the first board and seems to be correct by the schematics. I have steady power at the HB lead, and I am getting power on the HS lead from the first board after pressing the tv's power button (so the power relay must be ok). I haven't gotten any further than that at present. Schematics from the service manual are lacking in architecture from the real deal, so tracing is going a little slow for me right now. Any advice will be helpful.
    I am not getting power to the flyback transformer with the unit turned on. Pins 1,2,& 3 are showing 1.5 v, 50 or less mv on other pins stepping down to zip. I will have to trace back from here.
  • rtech Oct 08, 2007
    Sorry to mislead; I checked the flyback transformer on some pins I missed, pins 11 and 14 only showed micros, but pin 12 has 144 v. and pin 13 has 170 v. I did check the H-out transister, it seems to test correctly but I am not detecting the 123v that should be here when the tv unit is powered. (This is also connecting to the #2 pin on the flyback trans.) Where should the power be coming from for this circuit?
    For clarity, the H-out does short between pins B and E.
  • rtech Oct 10, 2007
    While tracing for picos, I found a slight discoloration on the positive side of the D9A10, RU 4YX Power Diode. When inspecting it, the solder flaked off the pin with a stab of a probe. The diode still tested good, and after resoldering, the television powered up.
    Do you think the solder gave to the heat of the Diode, or is there something else I might want to test for?
    Thank you for all your help, bigg t.
    Thank you again for all your help. You've been great.
  • 640 Answers
There are fuses on the psb (power supply board)check them with a meter for continuity.make sure your getting 110v into the board.grab a schematic from voltage readings to and from all the boards.if the psb is bad it'll cost around 500 bucks for a tech to come out and replace it.if you can narrow it down to a specific board you can replace it yourself.turn the set on and look at the power button color on the tv is it red or green?goto mitsubishis web site and get the troubleshooting flow chart,it will give you symptons and codes to find a problem.
Posted on Sep 30, 2007
  • 4 more comments
  • anthony james
    anthony james Oct 01, 2007
    if you havent checked the fuses check them.also unplug the tv for about half hour and plug back in and turn on.sometimes they will reset themselves.the problem your desribing sounds like the flyback transformer has went or ic's are burnt.can you open up the tv and visually inspect it?i will try to find a schematic for you.
  • anthony james
    anthony james Oct 02, 2007
    ok let me know
  • anthony james
    anthony james Oct 07, 2007
    from the schematic read the voltage going into the flyback transformer and coming out.
  • anthony james
    anthony james Oct 08, 2007
    check the horizontal output transistor for an open or short condition.
  • anthony james
    anthony james Oct 09, 2007
    trace before the hot and see if pico fuses (they look like small resistors and would be discolered or burnt) are in the circuit.check for open condition,if you see this you would then have to remove and replace the hot and shack would most likely have these.let me know
  • anthony james
    anthony james Oct 10, 2007
    it was probably due to heat.if there was excessive current draw you would have more than 1 failed component.
If Klixon relay attached to my compressor rattles, is it definitely no goad?
If the relay was faulty, the compressor would not start when cold. To test the relay put a continuity meter in the 2 pins for common and start. there should be no reading. Turn it upside down there should be continuity. If there is a capacitor attached to the relay as well, change it as it may be failing. Apart from these, check all else is working ok, particularly the condenser fan and gas level. if all else is ok, the compressor is overheating and siezing and will need replacing.
Apr 23, 2014 | Freezers
Recurring problem with inaccurate clicking
This is most likely a faulty digitizer this part is over the lcd screen and can be replaced quite easyly.
Jul 18, 2008 | Dell Axim X50v Pocket PC
So my 1990 corolla just stopped working we go to turn it on and get nothing only a small click in the fuse box under the hood Have changed fuses and batterery Was working fine until the batterey went flat...
It sounds like you have a problem with the starter solenoid or the starter relay. Usually, a "click" heard under the hood with a good battery indicates a faulty starter solenoid. In this case, the starter wants to work, but the solenoid which is usually attached to it won't transmit the necessary power to run the starter and crank the engine. Starter replacement is the only remedy in this case. If the click is heard from the fuse box, then it may only be a relay that is the culprit. Try swapping the starter relay with the horn relay or another one that has the same part number. Be sure to also check that the battery connections and grounds are clean and tight.
Apr 23, 2014 | Cars & Trucks
Turn key, no start, dash dead, but intermittent symptons
First I would look for voltage drop of both end of battery terminal.not a look or seem tight . you have to do it (voltage drop) and terminal at alternator.
now does alternator charging. take voltage of battery
if the problem occur have voltage of battery taken
like I read your problem it looks like wiring terminal ground and positive
the noise you hear is probably low voltage to a relay and the dropping voltage make the relay switch inside relay cycling noise click or buzz
Oct 05, 2013 | Chevrolet Cavalier Cars & Trucks
Can know one solve the problem of the wipers on 96 plymouth voyageur why they will not come on the back one work fine have tried new motor new fuses and cant find the problem would appreciate if someone...
system should have a wiper relay in fuse panel,can a audible click be heard from dash area or arround fuse panel or exterior of firewall/engine compartment when wipers are turned on,if not locate relay (see owners manual) and check for power at relay with key on first then check for power out of relay when wiper switch is turned on,fuse should put power to relay when key is on,relay should put power to wiper motor when wiper switch is turned on
Oct 10, 2009 | 1996 Plymouth Grand Voyager
No dash lights when your lites are on out of a 1997 toyota hilux 4wd deisel .no fuses are blownen?
i have a 1992 hilux surf import turbo diesel and my head lights go on but no dash lights indicators work fuses keep blowing what does this mean??
Sep 11, 2009 | 1997 Toyota 4Runner
Refrigerator won't cool
Hi!!! you have a problem with your current relay change it.Its shown here If it still dont work the your compressor windings are shorted.good luck.. 78e052d.jpg
Jan 21, 2009 | Kenmore Refrigerators
Televison & Video Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
