GE AGQ10AJ Thru-Wall/Window Air Conditioner
Problem for GE AGQ10AJ Thru-Wall/Window Air Conditioner
A/c doesn't remove moisture in the room?
By probbins4 on Apr 27, 2009
a/c doesn't remove moisture in the room? even when exchanger is set on open or closed--no moisture in collection tray either
model #agj3211daxt2    G.E.
Solution #1
posted on Apr 29, 2009
Not Rated)
mundy43
Rank: Wiz
Rating: 77%, 16 votes
An A/C unit is a dehumidifyer BUT Unit are rated in Pints of water, a Unit in Florida might need a de humiditiyer connected to it, the air is heavy with humidity. Another reason is that the Unit is under sized or not allowed to run long enough (?) Infor. on what State you live in would help and the size of the apt. or house the unit is covering. The best T / H would be 70* and 55 H and that would be on the cool side for most people , avg temps in a house would be 74* 65%, body temps are 98.6 most A/C unit are rated at 90* amp temp ( outside ) if the condenser is dirty this will cut the performance on a hot day over 85* Keep unit clean -replace filter (s) . If your getting a 15 degree reading between outside and inside your doing good the best would be 20 degrees ( depending on heat load) windows, and sun. Actic fans remove 30% of the heat -it will drop the temp from 120 to about 85, this can save you a lot of money in A/C bills and help cool the house in warm day when you don't need the A/C.
Was this helpful?
Yes
No
Popular Solutions for GE AGQ10AJ Thru-Wall/Window
Questions and Unsolved Problems for GE AGQ10AJ Thru-Wall/Window
Do you recommend GE AGQ10AJ Thru-Wall/Window Air Conditioner?
Answer
Answer
need wiring diagram dometic a c unit ser. no..238 00366 all wiring has been cut loose. from... (More)
Answer
repairs to tunturi 660 treadmill Error message of E1 is on the led display after I enter my weight... (More)
Answer
I have a Ionic Pro Model No. CA-200B, and I am trying to find a repair/service place in my area that... (More)
Answer
We had our air conditioner for one year now and it is a Arctic King Air Conditioner, a small window... (More)
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in Newport, KY
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
