Question about Sony STR-DE825 Receiver
Protector message i have a sony str-de825 and is giving me a protector message, how do i reset it and make it work again? thanks
  • stickboy Jan 08, 2008
    I have the same problem.
  • beth77998 Jan 15, 2009
    Hi I have the same problem with my receiver, didnt found out whay hapens, thanks Beata
    let me now beth77@wp.pl
    Sergeant:
    Champion:
  • 319 Answers
The only way to reset protect is to eliminate the problem which activated it. Problem may be insufficient line voltage or unit's output circuit. Have unit checked out by prof, tech
Posted on Apr 13, 2008
Protector light on sony str-de825. If everyone is having this problem and doing a hard shut down does not work, does no one ever take it to a professional? If so what did they fix on it?
In most cases the output is faulty as the MOSFET's shorts and so the drive board has to be changed. This is an expensive replacement and many when the estimation is done opt out. In some cases the protection is due to the fault of the protect circuit, failure of transistors or passive components.
Since most of the board are hard to access , the work estimation is high as boards are replaced.
Oct 01, 2011 | Sony STR-DE825 Receiver
Ca I hook up mt MP3 to mt STR DE825 receiver? If
yes either buy the sony dock for mp3's or go to Radio shack and buy the adapter that goes from a headphone jack to a red/white RCA plug get the gold tipped version and just use an open interface on the back phono, tape, whatever you have open.
Nov 25, 2009 | Sony Audio Players & Recorders
When choosing a mode such as dvd or video the receiver dispays the word protector and then doesn't function at all. Why would that be?
This usually means a short in the wires, or you have very poor ventilation for your system. You dont normally see this unless the volume is extraordinarily loud or the unit is overheating. I hope this gives you a few things to look at or try.
Jul 31, 2009 | Sony STR-DE825 Receiver
Power button broken
sony are pretty rubbish at offering patent parts, my suggestion as poor as it is would be to approach sony for this part they will recommend a retail outlet that can supply it
Jul 19, 2009 | Sony STR-DE825 Receiver
A "protector" warning appears when turning on.
there could be a short in one of the connections or your power supply could be fried also ive seen some models with internal fuses that have blown
Jun 30, 2009 | Sony STR-DE825 Receiver
Right front speaker channel has a lower than usual output...
very basically try swapping over the speaker cables, if this doesnt work i suspect you are in need of a new ouput i.c. these can go if the speaker wires are touched together, unless there is a protection circuit.
Jan 25, 2009 | Sony STR-DE825 Receiver
Protector off
Cambiale los IC de audio que esten dañados por eso se pone la leyenda protected.
Mar 24, 2008 | Sony STR-DE825 Receiver
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
Sony receiver str-da2000
Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Jul 14, 2007 | Sony STR-DE825 Receiver
Sony STR-DE825 Receiver Logo
916 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
