I will try that, I have to make a big mess but this time I will get a shop vac, that will help Can you please give me detailes instructions on how to take out the drain pump. That would help a TON
There are two different style drain pumps....lay the machine on its back and remove the axcess panel on the base of the machine. The origional style pump is a 2 peice design and it is easier to service there are two hoses and two clamps that when removed the pump assy will seperate from the drain motor. check to see if the impeller is jammed. The new pump is a one peice design and has to be removed to be serviced.
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed
you may want to check your drain catch by removing lower front panel and unscrew cap on front of pump, you may have a restriction or not using HE soap, before you remove cap from front of drain pump, attatch shop vac to washer drain hose and remove all water or you will have a big mess, if none of this works you may have to replace pump
