Question about Motorola Mobility RAZR V3m Cellular Phone
I can not get the phone out of EV mode?
The red 'EV' is on the display and my text messages don't send in this mode for some reason. I want to get the EV off. How can i do this?
The EV is not a mode of the of the phone, it's a service status, representing the data-transfer rate your phone can handle in your current area. The text message problem is likely not linked to the EV symbol.
Posted on Oct 06, 2007
I can not send any texts. Had no problems before. Keep getting the red exclamation point and say wont send
Sep 21, 2011 | LG Ally Cell Phone
Everytime I try and send a text message, I get the message, "send failed" Please could you help me!
Usually this error occurs when text messaging has been disabled for some reason. Do you currently have a limit to the amount of texts you can send that may have been exceeded or did someone remove texting from your phone without your knowledge?
Jun 27, 2011 | Cell Phones
I Can't Send Text Messages.. It Fails and the
Go to messages
Then text messages
Then to options
Then SIM Messages
Then delete the SIM Messages.
The memory after deleting sim messages is empty,and you dont need to delete any application
Jun 11, 2011 | Nokia 6682 Cellular Phone
When I tried to send the text message on the screen it says sending message but it then it will be just transfer to the outbox and won't be sent. why is that?
k660i can't send texts stuck in outbox problem
1 move the text that can't be deleted from OUTBOX to DRAFTS
2 if you still can't delete it go to SETTINGS-FLIGHT MODE select SHOW at STARTUP
3 switch phone OFF and ON again. select FLIGHT MODE at the beginning. switch phone OFF and ON again
4 select NORMAL MODE if asked. go to DRAFTS and delete that message
phone should be working now
Jun 01, 2010 | Sony Ericsson K660i Cellular Phone
I appear to be locked out of sending and receiving messages in the message section create and inbox is ghosted out, my samsung M110
Check out this link below to download a PDF manual for your phone. Just copy and paste into your browser.
Send a text message from page 20 in your manual:
1. In Idle mode, press [Left].
2. Enter the message text and
press [OK].
3. Select an empty location.
4. Enter a destination number
and press <OK>.
5. Press <Send> to send the
View a text message from page 21 in your manual:
<Menu> and select
Messages → Text
messages → Inbox.
2. Select a text message.
From page 5 in your manual:
To access Menu mode, press <Menu> in Idle mode.
Option 5 Messages
7 Settings
Option 9 Phone settings
10 Reset settings
If all else fails you can contact Samsung at 1-800-726-7864.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
Oct 16, 2009 | Samsung M110 Solid Cell Phone
No names on text messages
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
Jan 23, 2009 | Nokia 2610 Cellular Phone
How can i configure message services to text someone?
First, I assume you have a service provider, a valid cell phone number and that your service provider has enabled text messaging as part of your plan.
To send a text message, go to "Messages", then click "Compose SMS", "[Use Once]", "SMS".
Type the cell phone number of the person you want to send the message to.
Click the trackwheel, then "Continue".
Type a message.
Click the trackwheel.
Click "Send".
If you still are not able to send a text message, you need to verify that "fixed dialing mode" is not enabled. To do that:
Go to Phone Options.
Click "FDN Phone List".
Click "Disable FDN Mode".
Dec 29, 2008 | RIM BlackBerry 7290
When sending a text msg, it goes to outbox, wont send
I had the same problem and I read on down and saw someone's phone was stuck in flight mode. I remembered that for some reason, my phone was in flight mode the other day, so I went in and took it off. I realized the problem had been since that time. So, I put the phone back in flight mode and was able to delete the message from my outbox. I put it back in normal mode and now I can send texts. Yes!!!!
Nov 29, 2008 | Sony Ericsson w580i Cellular Phone
GSM mode
First of all, what service do you use? I'd assume you are using Nextel, which is iden. For this reason, setting it to gsm doesn't work. iden was apparently the last setting used, so "last active" also works. Motorola, for some unknown reason, decided not to allow Nextel users to text message.
There are two ways around this.
1. One is to send a multimedia message with only text (no pictures, sounds, etc). This should be treated as a text message.
2. The other way is to follow this guide, which should allow you to change the registry on your phone and get rid of the message. Note that the first posters made the guide for telus users, so be sure to use the nextel sms number (found later in the thread, I believe).
Jan 01, 2008 | Motorola Mobility i930 Cellular Phone
How do I send a text message?
open the phone, press yes(left side), scroll down to `new message`, press yes again, type in you text message, it may be on predictive text, to remove predictine text press `no` (abc mode)and then press `yes`, to send the text press `yes`
scroll down to send, press `yes`, type in the phone number of the reciepiant, press `yes`
if the phone number is saved in the phone instead of typiny it in press `yes` and scroll down to the number press `yes` and press `yes` again ... job done??
Sep 20, 2007 | Samsung SGH-A800 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
242 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
