Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Noisy lines in photos
My EX-Z60 had been working fine for a few months, but suddenly began showing ugly line noise in all still photos taken. I've tried resetting to factory defaults, swapping out the memory card and battery (as well as taking photos using the native camera memory), all with no luck. Movies taken don't have the problem. Has anyone else experienced anything similar? I see that there's a firmware upgrade (1.01), out of desperation I will probably try that.
You may have a problem with your lens unit.
Posted on Apr 07, 2008
Casio Exilim EX-Z60 6MP lines
No, it is not caused by settings. Probably CCD sensor is bad. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Sep 18, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim EX-Z60 used very little. All photos very messed up!
the shutter is bad in low light it will have banding stripes in bright light it will be white . must repair shutter or replace.
Apr 14, 2009 | Casio Cameras
Casio EX-Z60 camera - photos are whitened or brightened
If you enlarge the picture you have just taken, is there same lines running accross the picture?
If so, the shutter magnets are causing interferance and causing the picture to overexpose and have tiny lines running through it.
In Australia the complete lens will need to be replaced as the shutter does not come seperate and this is very expensive.
Sorry for the bad news.
Oct 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EX z60
A few possiblities:
This could be the CCD block, or the image processor area, or failure in the memory. These are just a few examples.
The service tech will change the defective boards and parts, and then go through the calibration procedure.
Jerry G.
Apr 28, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Picture Problems
Unfortunately the lens shutter mechanism isn't working properly. If a picture is taken in bright light, I'm guessing the photo is way over exposed? The best solution is to replace it with a good, used lens assembly.
Jan 14, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
Dec 02, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Pictures taken during the day come out VERY bright, even white
Might be worth flicking through all the settings menus for a few minutes - look in particular to see if you've got it out of Auto into Manual Exposure, or if somebody has accidentally selected a "brighten everything up by a couple of stops" mode. A.
Jun 24, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Very Bright Outdoor Photos with lines
The shutter is stuck. The electronic "noise" created by the solenoid trying to move the shutter blades causes the lines on your pictures. The bright outdoor pictures is due to the fact that the shutter is jammed open. You can try tapping the camera on the sides and bottom. This may jar the baldes loose. Failing that, you will have to find a shop that can obtain a replacement lens assembly for your camera.
Mar 30, 2007 | Casio Exilim EX-S600 Digital Camera
Help
Do the pictures have lines across them as well as being blurry? If you see the lines then your shutter is stuck open and it will require repair. The shutter has to close for the image sensor to properly record the image. If they have no abnormal lines on them, are they "out of focus" blurry or is it more of a streaked motion blur kind of thing? If you do need to get the camera repaired you should check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Feb 27, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
55 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
