Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi hdtv1080 projection tv
Horizon line over the picture? what to do? thank you!!
Picture decides to go out , sometimes for 2 or 3 days then turns back on its own.....what could this be?
Posted on Jan 10, 2008
SOURCE:
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi hdtv1080 is stuck on camcorde, how can I get it off?
When I turn the Mit. 1080 on, the green indicator light comes on for about 3-5 seconds then it goes off. TV never comes on (no picture or soun, nothing). What is the problem. thanks
Feb 06, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hi, I'm seeking information on a power issue, I have with my HDTV1080 integrated Medalion series, Model #65869. My unit does not power up! I have a constant blinking green light that does not go away, even...
This is due to bad capacitors in the power supply. You can try to replace them yourself or call Mitsubishi for help. Check AVS forum with your model number for tips on a self repair
Feb 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Red shadow
ITS A 2003 HD MODEL,REPAIRING WOULD COST 250.00-350.00 WHICH SEEMS A LOT BETTER THEN BUYING A NEW TV. I RECOMMEND THE HIGHER REPAIR AND GET THE ORIGINAL MITSUBISHI IC'S.
May 31, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Yellow and blue shadows
You can try adjusting the convergence which will be in the Advanced Menu of your TV. If it will not adjust properly then you need to have a qualified technician repair the set.
Jan 29, 2009 | Mitsubishi WS-55513 55" Rear Projection...
I have a HDTV1080 integrated Mitubushi TV.  Tried to turn on the tv but the timer green light started blinking and has not stopped and tv will not turn on.  What is wrong with this tv?
you gonna need some technical skills to replace the parts that are bad on your tv,but anyway check the power supply first,look for some swallen capacitors.and replace them that is going to be your first step.
thanks.
[email protected]
Jan 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Pull out the power cord from the outlet for about one minute and then replug it. The blinking will restart for about a minute or less and then the set will turn itself off. You will then be able to turn it back on in the usual way with the remote or power switch.
I believe this is caused by a power surge or a momentary power outage.
SG
Dec 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
