Question about Samsung SCH-i730 Pocket PC
Samsung i730 is frozen at align screen
My pda is frozen at the align screen i"ve tried hard reset, soft reset, recharing, leaving battery out for hours, nothing works Please Help
  • 1 more comment
  • Anonymous Nov 03, 2007
    I cant get the main screen because I cant get passed the align screen. I have pressed on the target. the target moves but when I stop it stops. I have taken the battery out, charged it, left it on. I called verizon and they had no idea why.
  • mizzamy Jan 07, 2008
    the phone will not align to get to the next screen.
  • Anonymous Feb 23, 2008
    The screen alignment process freezes at the first cross. There is a bypass utility called RemoteCalibration.exe but this will only allow a skipping of the process. In which case your phone is no longer a paper weight, but you have to control it with the buttons only. I would apprectiate a solution. fembotnumber6@hotmail.com
I don't have the solution, but this is directed to "Guest" (that posted on Nov. 3, 2007.): I don't think you'd want to call Verizon because they're simply the carrier for the network. Samsung made the phone, so even though it says "Verizon Wireless" on the phone, the people you should contact would be from Samsung. Samsung would know more about the techical details of the i730, since they manufactered it. Sorry this is so long......
Posted on Jan 11, 2008
PDA will not perform any of my commands..its frozen
Hello, Tallman.
I'd suggest to perform a soft reset then a hard reset, if the soft reset doesn't work.
Then if necessary, as this may or may not be a simple solution, depending on your particular brand and model:
Remove the back of the PDA. Remove and reinsert the battery.
Hope this helps.
Jan 09, 2010 | Palm Computers & Internet
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
Screen align problem
try to do hard reset if its not works
try to update rom image
if still not works try to replace your touch screen to new one
Dec 15, 2008 | HP iPAQ H3950 Pocket PC
Samsung i730 pda smartphone
try sliding the keyboard out if thats doesnt work the battery might be low or go to: start,settings,system,backlight go to the brightness tap and select a backlight setting
Oct 07, 2008 | Samsung SCH-i730 Pocket PC
My e2 frozen on the palm powered logo
Okay here it goes, your going to want to leave it on for however many hours it takes to completely drain the battery then you're going to want to recharge it back to normal charge, and try restarting it again. This will delete completely anything that is keeping it from restarting properly. If you did open up the machine without following "antistatic procedure" you may have fried a component on the board and then your in trouble
you'll need to salvage a board from another tungsten and put it back in your PDA and hope you put it back together right
May 28, 2008 | Palm Tungsten E2 Handheld
Samsung SCH-i730 Auto Reset
Check out this post...
http://pdaphonehome.com/forums/samsung-i730-i830-i830w/87922-internal-battery.html
Hope it helps. I haven't tried it as yet, though.
Feb 01, 2008 | Samsung SCH-i730 Pocket PC
Ipaq rx3115 frozen
Red LED light means a major problem at the charging of the battery.
You have several options to repair it:
1. Leave several hours the PDA with not battery and unplugged from the AC power adapter, then put the battery and leave charging it.
It's more likely that the red light will appears again, but leave plugged it. Sometimes will start charging and blinking with orange color after 30 minutes or so. After that, it will work normally.
2. Use other good working battery to test it.
3. If the above two steps fail, then there is a good chance that the mainboard has a problem, and needs to be fixed or replaced.
Best regards,
Jan 25, 2008 | HP iPAQ RX3115 Pocket PC
02 xda II s pocket pc pda
Upgrade ur ROM to latest version. it will help I think.
Jan 14, 2007 | O2 Xda IIs Pocket PC
Samsung SCH-i730 Pocket PC Logo
450 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
