Have you checked the wiring that goes to both the Crank and Cam sensors? Most of the time the wires are close to a heat source (ie: exhaust manifold) and the plastic covering starts to melt causing the cooper on wires to make contact and thus making engine stop, you will have to take off the protective covering as well as tape around the wires and inspect each and every one. Had same problem with Dodge caravan, it turns out the Crank Sensor plug wires were melted together. Good Luck.
SOURCE: 2003 stratus both sensors replaced still unresolved
Have the exact problem. Replaced cam sensor and timing belt. Still happens intermittently. code is p0344.
SOURCE: 2003 stratus cam sensor replaced still unresolved
you bypassed the wires that connect to the sensors? that would have been my first guess the harness that plugs into the sensor. after that i would check the ground connection from the ecm. wouldn't hurt to check the battery posts too. if the battery posts are oxidized you can have all kinds of goofy electrical problems. hope that helps.
