Rank: Guru
Rating: 88%, 3768 votes
To my knowledge, this head unit (Sony CDXF7000) uses individual 52 watts amplifier (X 4) whose output to the speakers require that none of the speaker wires be grounded or crossed/shorted.
Please check the speaker wiring with the use of an ohmmeter (or a multi tester) with all the speakers temporarily disconnected. Verify that none of the 8 wires reads 0 ohms to body/chassis ground or to any of the other wires.
As you have checked the wires area:
front left > + red & - white/black stripe;
front right> + gray & - gray/black stripe;
rear left > + green & - green/black stripe;
rear right > + purple & - purple/black stripe.
Rewire should it be necessary. If the wiring fully checks out, it may be that you have a fader component failure inside the unit (though honestly rare). You can also check if there is no bridging modifications done; converting your 4 amp-4 speakers original design to a bridged 4X52=2X100watt amp to 4 speakers paralleled to 2.
Another area you can check/try is by varying the DSO settings - 1,2,3,off.
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Comments:
Sep 30, 2007
- Oopps, should read >
front left > + white & - white/black stripe;
