Question about Acer Aspire 5100-5480 Notebook
Charging problem! My Acer Aspire 5560 laptop is only a year old. It needs to constantly be on AC power, even when I charge it, the moment it is taken off AC power, it displays the LOW BATTERY icon and asks to immediately be switched to a power source. The charger adapter box has a green light (shows its working?). I've even tried charging it the whole night but it still says LOW BATTERY when I take it off its charger. Please help, thank you!
  • Anonymous Jun 25, 2008
    I HAVE THE SAME PROBLEM EXACTLY
    Brigadier General:
  • 6,966 Answers
Hi, No other possibility, weak or dying battery, replacement therefore is needed. Good luck and kind regards.
Posted on Sep 30, 2007
    Guru:
  • 120 Answers
Simply put, your battery is broken. Lithium Ion batteries in laptops can have bad cells. Inside your laptop battery are numerous smaller lithium ion batteries about the size of a AA battery. One of these is bad, maybe a lot more than one. If you are very tech savvy you can dismantle the battery and using a multimeter figure out which cell has gone bad, then simply order a replacement cell online and solder it back on. If you're a regular user I would highly recommend you don't attempt this. I would suggest you check on ebay for somebody selling a replacement battery for your laptop. That would be the easiest and cheapest route.
SOURCE:
New Acer Aspire laptop 5560-7402 beeping and flickering
If it's new, return it A.S.A.P. for repair/replace, Unless it's been damaged or theated harshly, their is no reason for it to be giving you trouble in a month. If the AC jack is pulled, yanked, tugged...etc. it could damage the inside connections of the AC jack.
Nov 28, 2012 | Computers & Internet
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire One battery not charging
your probably going to need a new battery
Mar 25, 2010 | Acer Aspire One AOA150-1784 Netbook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
I have Acer Aspire ONE 8.9" but and it is
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jun 30, 2009 | Acer Aspire One AOA150-1784 Netbook
Laptop turns off when power cable is taken out even though battery is 100% charged
sounds like the system has a problem taking power from the battery, but is able to send power to it for charging purposes, or the battery indicates a ful charge, when in reality it is bad.
If there's a way to borrow a known good battery for testing purposes, you might narrow it down.
I'm sorry, I'd need to see this one to offer any further advice.
Good luck
Nov 25, 2007 | Acer Aspire 3680 Laptop
Charge problem!
It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Follow the below link for a step by step on how to build your own battery http://www.metacafe.com/watch/479447/laptop_battery_hack_youll_save/
Sep 30, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5480 Notebook Logo
135 people viewed this question
Ekse
Alun Cox
