Need a transformer
SOURCE: I have a SIP Ideal 350 Super 3 phase mig welder
The most eco way to fix is to replace the control panel 7902/S
SOURCE: SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
I have been told that I need a new transformer, can someone tell me if it is possible too get the old one recondition . If not where can I get a new one.
