Question about Insignia NS- 27" TV27 TV
Sound problems my t.v is brand new and on certain channels there is a constant "tapping" sound. it is not on every channel because then i would just take it back and there is no way to adjust the sound in the menus. any info would help. thanks
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
As you say that some channels sound is ok. it sounds me that it is a transmission problem or tv not tunned properly. reset it & tuned one more time hope it will be ok.
Posted on Oct 01, 2007
Just got the Protocol ToughCopter 2, i charged the heli for 2 hours and put fresh brand new batteries in the controller and the controller does nothing but flash the red light constantly. i have repla
check the helecopter see if it has a chennel number selection or it might have channel A channel B and Channel C. Make sure the remote and the Helecopter are set on the same channel if it has multiple channel settings.
Dec 25, 2014 | Protocol Tough-Copter 3.5-Channel...
Interment or no volume on certain channels.
make sure set not set to sap mode as this can blank audio on certain channels
Sep 03, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
My vizio tv is practically brand new as of christmas, when a movie or even tv is on the voices are very soft and the music or background noises are EXTREMELY loud, so I am always turning the volume up and...
I had this problem with my previous TV (Syntax by Olevia, an off brand). It only happened to me on certain channels, and for certain shows. What is happening is the TV station is broadcasting the audio in Dolby 5.1 format. For some stupid reason, the TV is playing the background speakers (effects) instead of the speaking parts. You get a little bleed-over of the voices into the back speakers, so voices are there but really quiet. Unfortunately my TV didn't have any surround sound options to fix this.
See if your TV has a surround sound option. Otherwise, you will need to connect the TV sound output to a surround sound system that can properly decode the audio channels.
Feb 06, 2011 | Televison & Video
No volume on certain channels
If you are using an antenna to recieve digital channels, if the signal strength is low on certain channels the sound will not be tuned in. Try adjusting the antenna. If it is cable there may be a problem with the cable run.
Dec 27, 2009 | Dynex Televison & Video
No Non-Hd sound
In a nutshell, there is no solution to this problem. The new Insignia TVs have a compatibilty issue with certain HDMI connections. The best thing is to return the TV and purchase another brand. I bought the LG w/built-in DVD and everything works great.
Feb 05, 2009 | Insignia LCDTV26 26 in. Television
TV gets stuck on channel, won't advance past channel 7.1
Try doing the Channel Search again. See if that helps.
If not, sounds like the Digital Board could be defective. Since this TV is brand new suggest calling your local sharp authorized service center to replace that board under warranty.
Mar 16, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
No sound on some channels
Had same problem on Viera 3D Plasma TH-P54VT20A
Select Sound from setup menu and ensure SPDIF Selection is set to PCM (not Auto)
Feb 28, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Mitsubishi TV
Hi jmvca:
Most likely the tuner is starting to fail. When it is first turned on, tap or slap the side of the cabinet to see if it makes any difference.
The set will have to be repaired in a shop when it goes out completely.
Feb 22, 2008 | Televison & Video
Only left/right have sound during the test
all of the channel are resonding to the test. but you cant notice it bec 5.1 speakers, each channel are designed to respond to a certain frequecies.  the L/R channel your talking about have the mid-range frequecies so it responds clearly compared to other channels...
hope that helps...
Oct 16, 2007 | Logitech Z-5500 Computer Speakers
Insignia NS- 27" TV27 TV Logo
37 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
