SOURCE: Constant clicking from flasher unit
The flasher unit has gone bad and needs to be changed. The flasher module is a part of the hazard module also. The clicking is the unit is still working but there is not enough voltage to activate the lights to flash. It's common on the Malibu's and other GM product cars similar to the Malibu like Grand Am's Ect. I believe Auto Zone has the replacement part for you car and is more reasonable in price then the dealer and the y also have the step by step instructions to replace the flasher module. Good luck and keep me posted, be glad to help.
SOURCE: Flasher clicks when turn signal and flashers are off
The E flasher switch is probably bad,there was recall on alot of these if is not 10 years old or has less than 150,000 miles on the car. If you fit this take it to a dealer and ask, that won't cost nothing
SOURCE: 2000 Silverado making constant turn signal clicks
your ring or combination switch in the column is bad. the combinationswitches fail. not hard to replace. remove battery cable. pull covers off column and unscrew with torx. also unplug connectors.
SOURCE: Hi I have a problem
You'll need to replace the turn signal multi-function switch. It is grounding the white feed wire from the flasher when it is not supposed to. This is a really common problem with these. I have heard of people cleaning the switches with electrical cleaner and having that work as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: Turn signal flasher keeps clicking when turn
multifunction switch in the column is the reason for this.. it is common and see this all the time. replacement of this part will fix the problem. you can find cheaper parts from www.rockauto.com they have everything and they will ship it right to you.. good luck
