Question about iLO (2 GB) MP3 Player
How Do I Charge my Sans Mp3 Player
I plug it into the computer and it supposed to charge, but it don't.
  • 8,596 Answers
Make sure you ran the install CD first
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 05, 2008
SanDisk Sansa Express 2 GB MP3 Player (Black), battery status states 14% critically low....what does it mean and what actions should I suppose to do?
You need to charge the battery so you can continue playing your MP3player.
Connect the supplied USB cable into the player and then plug it into the USB port of your computer. The computer will charge up the MP3 player and you can also copy mp3 music and photos etc to the MP3 player.
Aug 25, 2011 | SanDisk Audio Players & Recorders
Have never owned one so I want to make sure I am doing this stuff correctly. It didnt come with much of a guide.I plugged it in to my laptop to charge it then it automaticlly says ok to disconnect. when im...
If you are trying to charge it, and your computer says "OK to disconnect", then you can just ignore it. This is your computer telling you that disconnecting the device will not adversely affect the computer. If it's your MP3 player that is saying "OK to disconnect", I can only tell you that keeping it plugged into your computer via a USB cord will probably continue to charge it.
If you're unsure, disconnect it from the computer and see if there's an indicator for the amount of battery life remaining on your player.
I hope this helps.
Mar 06, 2011 | Audio Players & Recorders
Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
Apr 18, 2009 | SanDisk Sansa Clip MP3 Player
Nextar MA 166 MP3 Won't Charge
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
-Tha Mp3 Doctor
Jan 24, 2009 | GPX ML648B MP3 Player
My mp3 player only works when it is pluged in to the charger.
Have you let the battery charge? You are supposed to charge it at least four hours the first time, or until it is full. You just need to leave it connected to the computer for it to charge.
Dec 30, 2008 | Coby MP-C7085 MP3 Player
I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
Dec 26, 2008 | Coby MP-C7085 MP3 Player
New pink apple ipod shuffle
Nothing is wrong you are supposed to let the ipod shufle charge a day after you buy it
now if you charge it again it would probably turn green.
Dec 20, 2008 | Apple iPod shuffle MP3 Player
My zen wont charge
It won't charge from an USB hub. It must be plugged intoan USB port on the computer itself.
Oct 29, 2008 | Creative Labs ZEN V Plus MP3 Player
Audiophase MP3 player
I had the same problem, so I got fed up and threw it against the wall...... Just kidding. I have a Motorola phone that uses a mini-USB plug-in charger. So I connected it to the mp3 player and plugged it in, looking for smoke. And Wala! it started to charge. The mp3 player has to be on. When you see a battery icon and it simulating being filled up, then you know that it is charging. Once it stops filling up, it's done. Good luck!
Also, if you use the USB cable in you computer, make sure that the mp3 player is on. I had absolutely no luck on charging this way, but maybe you can.
Oct 03, 2007 | Audio Players & Recorders
iLO (2 GB) MP3 Player Logo
24 people viewed this question
Top iLO Audio Players & Recorders Experts
Siul Oyaratgam
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
