Question about Motorola Mobility SLVR L7 Cellular Phone
Got wet my motorola slvr fell in the sink, either way the phones keypad isnt working now, it turns on with the on button but no other buttons work...i need to know in detail what i can do to remedy the problem, i can still use the phone if i use my bluetooth but other than that i cannot retrieve text messages or my voicemail or anything else that requires me to use any buttons.
  • 94 Answers
Ok , you will need a new keypad , these you can find on ebay if you search " replacement keypad for motorola slvr " these will cost you about 3 pound , and then to fit it you will need a set of torx screwdrivers remove the screws and then if you pull the front of the phone of it shud come off with ease and then you will see the old keypad and just swap it with your new replacement 1 , hope i helped .
Posted on Oct 18, 2007
SOURCE:
Button fell off phone.
No, you will have to replace the entire keypad or just stick it using some super glue. Don't take the phone apart.
Mar 24, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Instrument got wet
I had the same problem with my slvr.I removed the battery and took a hair dryer adnspent many hours slowly drying phone.Been working for two years now!
Feb 02, 2009 | Motorola Mobility SLVR L7 Cellular Phone
Ok I have dropped my slvr several times in water and they continued working. A few of my buttons came off and one day i got a little drop of water on my phone, and now the buttons tend to frequently freeze...
you must open your slvr then try to clean it with some PCB cleaner. try to put it back then test this will fix your problem. if still cannot you must change your Keypad board.
Aug 15, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Keypad
bring it to a cell phone center...
May 07, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola L7 keppad not working
hi,
Im getting error
switch PTT service on from settings.
Mar 20, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola L7 keypad not working
hey, i had the same bloody problem, exactly the same. but after i removed and inserted my battery several times, it was fine!!!
ANd the keypad works fine now.
Keypad
do u have the same problem while dialing numbers
Dec 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Motorola SLVR buttons do not work
I don't know but mine's doing the exact same thing. Mine also keeps the screen on almost all the time, sometimes it turns itself on and back off and back on for hours. Once every button EXCEPT the red button worked... and once only the top left button worked, so i could answer calls but couldn't hang up. My friends enjoyed messing with me for that one.
Dec 01, 2007 | Motorola Mobility SLVR L7 Cellular Phone
The buttons on my phone won't work
what you should do first is have the firmware on the phone reflash , then if that does not work then you can buy a new phone.
Nov 08, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Keypad doesn't seems to work - seems locked - gets incoming calls
JOSE18
under tools there is a record option. erase all things that have been recorded. the button on the top screen on the right hand side allows you to record phone calls. You have probably been hitting it on accident and recording calls and such. Let me know if this works.
Nov 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
