Question about Philips Magnavox 27MS343S 27" TV
Acess code eveery time we turn it to channels it asks us for the code and the person who owned before don't remember it so how can we get it off in order to watch them
    Genius:
  • 1,694 Answers
Try activating demo mode--ON==hold both vol up and chan up on front of set for four seconds, then do same again==did it clear code lock? Let me know if you need more help.
Posted on Oct 04, 2007
SOURCE:
I just purchased a new RCA 32 inch w/ DVD. When starting up it asks if you will use Cable or Air. I have Dish Satellite and picked air. I only get one channel and if I try to go up or down channels I get a...
You should not have had to choose cable or air. When you have satellite it is considered the same thing as cable. Air is over the air rabbit ears antenna free programming. When you are connecting a satellite receiver you only have to turn to channel 3 or pick the correct av, component or hdmi input. Oh you must be connecting more than one television to the same satellite receiver. When that is the case tv #2 usually has to be set on a different channel and the satellite tv company tells you which channel. You still use the satellite remote to change channels and leave this television on one channel at all times. This television is good enough for its own hd satellite receiver connected with component cables or an hdmi cable though in order for you to see its full potential for displaying hd programs.
Jan 07, 2011 | RCA L32HD31 32 in. LCD HDTV
How to reset the door code on a ford expidition
from the owners manual
Programming your own personal entry code
To program your own code:
1. Enter factory set code (keypad will illuminate when pressed).
2. Press 1/2 control within five
seconds of step 1.
3. Enter your personal 5 digit code.
Enter each digit within five seconds
of previous one.
Do not set a code that includes five
of the same number or presents
them in sequential order. Thieves
can easily figure out these types of codes.
Your personal code does not replace the permanent code that the
dealership gave you. You can use either code to unlock your vehicle. If a
second personal code is entered, the module will erase it in favor of the
new code.
If you wish to erase your personal code, use the following instructions:
1. Enter factory set code.
seconds of step one.
3. Press 7/8 control and 9/0 control
at the same time within five seconds
of step 2.
The system will now only respond
to the factory set code.
Oct 28, 2010 | 2000 Ford Expedition
How do I change the code for key less entery on the key pad on door
Programming a personal entry code The factory set code cannot be reprogrammed but you can create your own 5 digit personal entry code. When pressing the controls on the keypad, press the middle of the controls to ensure a good activation.
Up to three personal entry codes may be programmed to the vehicle. To create your own personal entry code:
  • 1. Enter the factory set code.
  • 2. Within five seconds press the 1-2 on the keypad.
  • 3. Enter your personal 5-digit code. Each number must be entered within five seconds of each other.
  • 4. Press 1-2, 3-4 or 5-6 to indicate which of the three personal entry code positions you wish to use.
  • 5. The doors will again lock then unlock to confirm that your personal key code has been programmed to the module.
Tips:
  • Do not set a code that uses five of the same number.
  • Do not use five numbers in sequential order.
  • The factory set code will work even if you have set your own personal code.
  • If you program a code to a position that already contains a set code, the previously-set code will be erased.
Erasing personal code
  • 1. Enter the factory set 5 digit code.
  • 2. Within five seconds, press the 1-2 on the keypad and release.
  • 3. Press and hold the 1- 2 for two seconds. This must be done within five seconds of completing Step 2.
All personal codes are now erased and only the factory set 5 digit code will work.
Good luck (remember commend and rated this).
May 03, 2010 | 1996 Ford Explorer
I need to know how to change auto door lock code on my mercury mountaineer
i dont know if this will help you but to change the auto lock codes on a 94 mercury sablethat is set into your remote keyless entry system at the factory.you can program your own personal code to unlock the vehicle. this code does not replace the prminant code that is programmed into your system.
to program your own code 1) select five digits for your personal code. 2) enter the code the dealership gave you. 3) within five seconds, press 1/2. 4) within five seconds of pressing 1/2, enter your personal code, pressing each digit within five seconds of the previous digit.
the keyless system registers this second code. to open your vehicle, you can now use either code. the module only remembers only one personal code at a time. entering a second personal code will erase the first personal code, replacing it withe new second one.
to erase your personal code 1. enter the original code. 2. press1/2 within five seconds of step 1. 3. wait six seconds
the keless entry system auto erased your personal code and will only respond to the permenent one. i hope this helps
Jul 24, 2009 | 1994 Mercury Sable
Parental pin
Hi!
To unlock your set requires two steps: the first is to get past the lock screen.To do that, press the QV( or previous channel?) and 9 buttons at the same time when you are asked to enter your lock code.
Now that you're past the lock screen, find the menu that covers locking and unlocking. QV/9 (previous channel/9) is a one-time bypass; if you turn the set off, it'll be locked again when you turn it on, so you first need to LOCK it again, with a pass code you can remember (try 1,1,1,1). Once you lock it, you can exit from all the menus, then try to change inputs. It'll ask for a pass code, which you now know!
Please ask for further clarifications and rate the solution as Fixya if found useful.
Thanks
Rylee
Mar 14, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Keyless entry
I believe dealer has to re-program the new code.
Aug 29, 2008 | 2001 Ford Explorer Sport Trac
HELP!!! Personal Code Needed!!!
Press QV and 9 on Mits remote.................................T.
Jan 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
PUK CODE ERROR
PUK (personal unlocking code) is a code to unlock security code. Any phone allows three trial of inserting security code; If we insert wrong code three time it ask for PUK., and that is your problem. You have to ask your provider to give you that code. For that you have to call your operator's care centre or help line from landline of other card of same operator. Operator on line will ask you about your mobile no. and 2-3 question regarding your personal detail and provide the PUK code. Enter the PUK given my him & your cell will be unlocked.
Jan 08, 2008 | Sony Ericsson K610i Cellular Phone
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
