Question about RCA HDLP50W151 50" Rear Projection HDTV
The powewr button will not come on and stay on.
The green power button will come on and then flash and go off. The TV never comes on. unpluged and tried again with the same result.
  • David Whye Nov 23, 2007
    I am having the same problem, power light comes on and will flash for about 10 seconds and goes off, tried unplugging the set this has not corrected the problem.
  • kjk0315 Dec 02, 2007
    I have the same problem with the rca d52w23 the piower light comes on for a few seconds then goes off
    Sergeant:
    Champion:
  • 375 Answers
The set has gone into shut down because or an error,requires service call.
Posted on Nov 16, 2007
SOURCE:
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Tv will not stay on
Tv won't stay on - Fixya
www.fixya.com/support/t101679-tv_stay
Tv won't stay on My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds - RCA F27450 27" TV question. ... My TV will notcome on, when I hit the power button the green light flashes but the ..... Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
Why won't my TV stay on? ' Yahoo Answers
Nov 14, 2015 | Symphonic ST420FF 20" TV
I have a Mitsubishi WD 60738 and the stand by light on the front of the tv was staying on and was orange. I removed the power supply and blew out all the dust and reinstalled the power supply and now the...
Hello Jeff;
If the TV does not turn on or off, does not respond to the remote
control or the control panel buttons, or has audio but no video:
1.) Press and hold the POWER button on the control panel for ten seconds. The TV will turn off.
2.) Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost.
If the TV does not respond to the remote control or to the control-panel buttons and TV will not power on or off.
• Unplug the AC power cord for 10 seconds.
• Press and hold the POWER button on the control panel for 10
seconds to perform a system reset.
If the TV turned itself off and the light on the front panel started to flash:
• Momentary power fluctuation can cause the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again.
• If the TV does not stay on, press the POWER button on the
control panel for ten seconds to perform a System Reset. If this happens frequently, obtain an AC line power conditioner/surge protector.
• An unusual digital signal may have been received, triggering a
protection circuit. Wait for the light to stop flashing and turn TV
on.
If the TV will not power off, press the POWER button on the control panel for ten seconds to perform a System Reset.
Should you still have problems, call for assistance at 1(800) 332-2119
I would not recommend using compressed air or any other method that would blow dust around- since the dust could make its way into the set's circuitry via the grille or vents and cause problems. Use a vacuum cleaner with a brush attachment instead.
Mar 12, 2015 | Mitsubishi Televison & Video
No picture or sound read and green power button flashing.
This sound like a powewr supply problem, or a capacitor burn-out problem. Look on the back of your screen and see if ther is a reset button, if so, hold button in for 5-10 seconds, that way the circuit boards reset, if that doesn't work, or if there is no button, unplug tv, hold power button in for about 10 seconds, release button, plug in and try again. If that still doesn't work, then it is probably capacitors burnt out on the i.c. board. If your tv is still under warranty, then follw their instructions for service, if out of warranty, or if you have no warranty on it, take it to BestBuy, or Fry's electronics. They both have specialists trained in capacitor repairs for tv's. Just know that the cost of the repair may be as much if not more than the cost of a new tv of comparable size and quality.
Dec 18, 2010 | Televison & Video
Green Light Flashing in Power Button
so the sound of mouse click is from the button being pushed.
is the light flashing codes at you in the form of flashing?
looks like you may have a short in the p/s.
Apr 09, 2008 | Philips 55PW9363 55" Rear Projection...
61 in rca model # hd661w66
???...if course the green LED will go off ater a few seconds of unpluging it...LOL...anyway....power supply/deflection board will solve this problem
Feb 03, 2008 | RCA P61927 61" Rear Projection Television
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Green flashing power indicator light
similar problem with my Sony. Unplugging for 36 hours solved the problem for me
Sep 29, 2007 | Samsung HPN5039 50 in. Plasma HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
47 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
