Question about Whirlpool Calypso GVW9959K Top Load Washer
OK I have tanken off the drain hose and it still won't work
Ok I took of the drain hose and made sure that it was not plugged, and when I did WOW there was a large Title wave, major mess!!!! How ever it still won't work, the washer is still falshing LD "very frustrated please help"!!!
  • 447 Answers
The drain pump may be bound by a foreign object preventing it from removing the water. I recommend removing it from the washer and making sure the impeller is not bound.
Posted on Sep 30, 2007
SOURCE:
4yrs old 537 does not pick up. All motors seem ok. Clean every time after use.
Make sure all the hoses are not partly plugged. I had one that I took off my machine and put a little dowel rod through the hose inside. A pile of fuzzy dirt came out and works ok now.
Jan 05, 2015 | Vacuums
1994 oldsmobile 88 heater core
wow big job, ok here we go, cold engine drain cooling system,loosen clamps and disconnect hoses from core plug ends, under hood, now inside remove right side under dash panel,remove heater floor outlet duct,remove screws and clips that secure core cover,remove cover then core retaining straps and core reverse to put back together
Jan 04, 2014 | Cars & Trucks
Flush with fluid surpenion system why remove heating hose
surpenion system.? wow no year stated !!
what are you doing ,just a flush? of engine coolant
my guess you are reading the steps. and wonder why we do it fully
there are 2 flush ways. 1 is poor way and way 2 is ASE.
i will not mention shop way with the $10,000 machine.
1: poor way, open drain bottom rad, run water from rad cap
until drain runs clear. (ok on a 2 year old car. sure)
2 pro way.
he back flushs all cooling system parts and makes sure all flow good.
1: RAD (end to end)
2: HEATER CORE.
3: isc AND iac VALVES AND HOSES
4: THE BYpass hoses are flowing good.
other? sure. depends on engine option (size)
on my cars , IR pyro gun the rad tubes as a last check. (hot)
to be sure all tubes are working... ask.... a $15 tool , like no other.
it a choice,
Dec 11, 2013 | Toyota Land Cruiser Cars & Trucks
My LG front loader will not drain. I took the drain hose off, no clogs. Cleaned the filter, still won't drain. ???
if you can hear a humming noise when put on drain, this means the drain pump moter is ok but might have an object stuck around the blades! to check this you have to take off the drain moter which is behind the filter which in most models the base is open, so you have to take plug off from mains and lift the machine up and get to it from the bottom! it has 3 screws on it and its the moter which has the drain hose attached near it not the one without as most LGs have two moters one for drain one for circulation! take this moter out and check whats around it! it could be even string of some sort! make sure you put the screws in the exact place otherwise wrong hole would make it leak! take care! my advise would be to call local engineer which wont cost more than 40 to 50 pounds to fix! make sure you dont get ripped off by them saying the pump moter has gone as these pump moters very very rarely goes! im an engineer and i do this every day so i know! good luck!
Mar 01, 2013 | Washing Machines
I have a 1986 suzuki 650 savage the carb seems to have a problem. It started flooding gas coming out the over flow. I took it off and took the float cover off and replaced the needle needle set and float....
Yea these carbs can be a real pain sometimes to get right. First thing you need to do is varify the float seat is working and totally stopping all fuel flow.... and all the jets, main, pilot and choke circuit are absolutely clean. Bench test the float needle valve by connecting a hose to the carb fuel line nipple and letting gas gravity feed as it would in a run position. if it tests ok, remount it on the bike...
i'm guessing you have a vacuum petcock on this year model? If you do, it needs to be inspected.
In the "on" position you should have no gas flow coming through the petcock, In the "prime" position it free flows. If there is a hole in the diaphram the engine will **** gas and not air (vacuum) through the hose and it will flood. If you don't have a vacuum line on your petcock then it is a different kind. Be sure to check your crankcase, it could be way past full with gas that has entered, dont start your engine like that...drain it all out. make sure the air filter is dry. You will have to replace the spark plugs...a gas soaked plug won't fire.
Good luck, i hope this helps.
Jul 16, 2011 | 1986 Suzuki LS 650 Savage
Won't drain
the problem is either your pump or your hoses. this an easy fix. all you need is a screwdriver and a bucket to catch water. 1st unplug the machine and remove the drain hose from the drain. then try to drain the water from the washer by plugging it back in and setting the washer to drain. if no water comes out of your drain hose then you know your plumbing is ok. next put the drain hose back in the drain and take the cabinet of your washer. you will see your pump with 2 hoses connecting to it. one hose connects to the basket and the other to the drain. disconnect the hose coming from the basket and if water comes out then you know the basket is not blocked with any article of clothing. if both check out ok your problem would be the pump. write down the model and serial number to your washer and buy a pump. they are only about 15.00. remove the old and install the new. having a repairman like me install would cost about 150.00, so i advise you to do it yourself or have a friend help.
Jun 24, 2011 | Washing Machines
Jenn-Air dishwasher will not drain
Hello there:
I am assuming it washes OK
First remove the kick plate.on the front bottom
Is the pump running when it should be draining?
Is The solenoid (Wash/drain) pulling down when it should be draining? (If visable)
Left hand side attached to the pump housing.
If yes then you probably have a blocked drain hose or house drain blockage.
Undo the drain hose at the sink, often stuff can collect where the hose fits over the drain fitting and cause a plug. and also the hose can get clogged on the inlet side of the pump too ok?
If OK. Try to drain it into a pail. Be sure to hold the hose there firmly and put a rag/towel over the top of the pail or you will have water everywhere.
and fully inspect the hose all the way up to the pump .
Hope his is very helpful for you
Best regards Michael
Dec 31, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
I have a model HD-306 Haier dehumidifier which is hooked up with a hose to a drain. It has been working fine until several days ago. Water now is coming from the bottom of the unit onto the floor. I...
please make sure the unit is leveled.also make sure the hole in the drain pan not clogged.also the size of the hose must be fit the hole not smaller
Sep 04, 2009 | Haier 45-Pint Dehumidifier
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Washer will not leave the drain cycle
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
Jan 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
43 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
