Question about Motorola Mobility RAZR V3
Black Screen Hi, I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you have any solutions? Thanks
  • 16 more comments
  • Eagle612 Sep 30, 2007
    Thank you GEngineering. Your solution worked. My phone screen is working again.
    Thanks again.
  • lilkevia1 Dec 12, 2007
    The screen on my Motorola RAZR is black. I can dial and recieve calls but cant see anything. what can i do to fix it?
  • geminimax Apr 30, 2008
    my screen went off after i answered it when i had just got out of shower, think my wet hair might of done it, but that was 8 hrs ago and its still not working. cant make and receive calls but screen is black, got loads of txts waitng to be read!!!
  • Anonymous Aug 19, 2008
    Thanks from me too. It fixed my problem!!!
    I had a similar problem.. my phone randomly started actin up and the screen would jus go out evrytime i would hit any button, the creen would just turn white but the phone would still work jus a white screen.. i tried the solution and it worked but hopefully it will stay.. thnx ^_^
  • Chels-C Aug 19, 2008
    I have a razr and i have a black screen and when i turn it on i cant see anyhting and the keypad flashes...i might have gotten it a little wet can u help??
  • tonkinese93 Aug 31, 2008
    i dropped my razr in my cereal a few weeks ago. i thought it wuldnt be able to work again. but a few days later it was almost back to normal except sumtimes i hav to smack it to make it relly work.
    and last night my friend dropped it and now the screen iwss black again but i still recieve text messeges and calls so it still works. any ideas i can make it work without loosing any information?
  • Anonymous Aug 31, 2008
    Thanks
  • Anonymous Sep 01, 2008
    turn it on and off
  • murffiexoxo Sep 01, 2008
    Black screen also on my razor..love the phone..but noi screen
  • donald_a20 Sep 18, 2008
    motorola razr v3 screen is blank
  • Anonymous Oct 25, 2008
    my screen is black and i can hear sound but it wont show anything
  • Anonymous Nov 28, 2008
    The Thumb and finger soution worked a treat for my problem too. Many Thanks
  • evasalazar19 Jan 06, 2009
    I droped my phone and now the screen is black but the numbers still light up. what is wrong with it?
  • Anonymous Mar 05, 2009
    Exact same problem, I turned it off and when i tried to turn it back on, the screen had stopped working.
  • aleciawillia May 02, 2009
    My phone is working but the screen is black. Is there something I can do?
  • jassy902 May 03, 2009
    I try to charge my razr but it stills doesn't come on?
  • Anonymous Mar 27, 2014
    My motorola razr's screen went black. The phone still works. I can make/receive phone calls, but can't see anything on the screen. How to retrieve my contact info which is in the memory
  • 10 Answers
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
Posted on Sep 30, 2007
  • jong sky Nov 25, 2011
    ..hey' it works...thanks dude:)
Posted on Sep 24, 2009
How do i get the time to show in my front window
Posted on Aug 31, 2008
3 Suggested Answers
SOURCE:
toy_ladi
  • 484 Answers
SOURCE: I have a Motorola Razr V3. Very recently the
The reason your phone interior and exterior screen went black is because there is a problem with the flex of the phone.
The flex is the mechanism like a ribbon that connects the screen to the panel of the phone.
All you have to do is to replace the flex of the phone.
To replace it on your own, the process to do this are as following;
  1. Get the appropriate screwdriver (Torx 5 screwdriver).
  2. Remove the four rubber stoppers surrounding the screen to reveal four screws. Remove these screws.
  3. You can now remove the front cover. To do this, use a credit card to lever the cover up. The cover clips on and the levering motion will unclip it. Start at the top, then unclip the cover at the bottom, then both sides.
  4. Now detach the camera from the phone. Simply pull the ribbon away from the phone to release it.
  5. Now unplug the other ribbon. The ribbon attaches like a plug and socket. Simply lift it up to unplug it.
  6. The ribbon you just unplugged is the flex of the phone, so you have to unscrew the lower part of the phone to remove it completely.
  7. To open the lower part, you have to open the back cover and remove the battery,
  8. Unscrew the screws you see, than split it open with a credit card or the tip of your finger, apply a little force to open it.
  9. Then unscrew the board, you will see where the other end of the ribbon is connected on the board, then you can remove it and fix a new one.
  10. Reverse the process to reassemble the phone together.
Take care
Posted on Jun 22, 2010
  • 70 Answers
SOURCE: black screeb
hi, all you need do is to get an expert to help you change the FLEX..it is the flex that is faulty.
Posted on Jul 16, 2010
Black screeb
Jul 16, 2010 | Motorola Mobility RAZR V3
I have a Motorola Razr V3. Very recently the exterior and main screen went black. The phone itself still works (I can still call people and receive calls) but I can not see anything on the screens. Do you...
Take care
Jun 22, 2010 | Motorola Mobility RAZR V3
Display screen went black---otherwise, phone still works
display flap strip problem change it . it is also called as display flap PATTA
Aug 26, 2009 | Motorola Mobility RAZR V3
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Black Sreen
go on fixmaphone.omg and thay will ask you to post it in then that will ripace the screen
Aug 31, 2008 | Motorola Mobility RAZR V3
Black screen
you need to replace the flexcable on the phone to have it working once more.
Jun 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
My mobile phone (razr) screen is black but the phone still works
Hello!!!
Sorry to say that u gotta change the display ... costs u around 80$
Dec 28, 2007 | Motorola Mobility RAZR V3
Motorola razr v3 (black) screen has white blank
Well i suggest that you take the case of your phone and have a look at your screen maybe some of the screws have gone missing or the screen has just worn itself out? . Note youll need a t6 or t7 torx screwdriver to do this , hope i helped
Oct 17, 2007 | Motorola Mobility RAZR V3
Screen blacked out, need to download to sims card.
Use Motorola Phone Tools (MPT) to backup your phone to a computer. You can reload to a new phone if you have to go that route. From what your describing you just need to replace the flex cable.
Jul 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
4,082 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
