Question about Olevia LT37HVS 37 in. LCD HDTV
Power problems My Olevia 37" LCD set is shutting off for no reason and recently, has not been powering all the way back on - blue Olevia logo is dark, but no picture. Help!
  • 9 more comments
  • Linzh20 Nov 07, 2007
    Everything black. Disconnect/reconnect power cord and Olevia logo lights up blue. Hit power button and logo goes out, but no picture. When I hit the power again to "turn off", Olivia logo does not light. Repeat and same thing happens everytime.
  • eiche11 Nov 14, 2007
    Plug in the tv. Power light comes on. PUsh power from remote or on tv. nothing happens but the blue power light goes off as it is supposed to do. Cannot "turn off" tv with remote to get power light to turn on. Have to do it from the tv.
  • Anonymous Nov 15, 2007
    TV will occasionally not turn on. Blue light goes off, but television does not turn on. Only way to get television to work is to unplug television, plug it back in, and start over. Sometimes it works, sometimes it requires multiple tries. Olevia says it could be a power supply issue ($89), but no guarantees. TV is only 18 months old.
  • Anonymous Nov 19, 2007
    After watching the 37lthvs for an hour to 4 hours, it turns itself off. Unplugging don't work. If I wait 10-15 minutes, I can turn it back on. Timer is de-activated.
  • Anonymous Nov 28, 2007
    Purchased Olevia 37" HDTV 1 week ago and having power problems. Blue light is on but TV will not turn on either by remote or power button on front. Unplugging from outlet and turning back on does not help
    my lcd will click off in the middle of viewing and go black. i have to unplug and wait a few seconds replug and the blue screen will appear when i hit on/off button. it will continue this if i keep viewing but the time intervals between shutting down shortens. was hoping to find a solution from someone with similar problem.
  • Anonymous Jan 22, 2008
    My screen goes to the Olevia startup, then turns green, then shuts off. It 'reboots' and will continue this loop until unplugged.
  • titusjr0001 Sep 12, 2008
    I have a 42 242t that wont cme on. The blue light comes on in front but no action takes place. I push the power button up front nothing, the remote wont turn it on either. Is it broke ar am I not doin the rite thing. NO blue screen no sound what so ever inside that there is power circulating throughout that I can tell. Please help or someones getting hurt.
  • winroc7 Mar 23, 2009
    I have 32 532h olevia that would not power on. The blue LCD light is on in front but no action takes place even if I push power button on TV or remote. I also tried connecting my LCD (through service port) through laptop using USB cable and tried to switch on power but without any success. I also tried unplugging TV and leaving it to cool off for 4-6 hours and switching it on again without any luck..can someone plz help?
  • lg1775 Apr 09, 2009
    i have the same problem shutting off after sometime watching it flip the on /off switch on back of set and push the on/off switch on front and it comes back on help
  • omarjacobo May 18, 2009
    Same problem here... Somebody here knows where the fuse is in?
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Posted on Jul 01, 2008
    Problem Solver:
I need the codes for my Olevia 37" HDTV LCD. I have no manual nor codes and I can not find a solution. Someone from your fixya said to call Olevia but did not give me a ph#. Can U assist me better with the info which I need? What are the codes?
Thanks!
Doug3233
Posted on Jan 05, 2008
I've been told by TV repair folks that your issue is probably a result of some circuit being bad. He states that the bad circuit works when cold but as TV heats up, it fails. Solution, either pay someone to test all your boards or do it yourself with a multimeter.
Posted on Dec 16, 2007
Sell it on ebay and get a new one.
Posted on Nov 02, 2007
Olevia 265TFHD 65
FIGURING OUT YOUR PROBLEM IS ONE THING, BUT FINDING THE PARTS WILL BE THE BIGGEST CHALLENGE. I HAVE A OLEVIA 255TFHD AND IM CATCHING HELL FINDING PARTS. SYNTAX BRILLANT, THE COMPANY THAT MADE OUR SETS HAS GONE OUT OF BUSINESS. PARTS ARE SCARCE
May 11, 2012 | Olevia 237T 37 in. LCD TV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Olevia tv, no power
This the common problem for Olevia TV, open up the back cover, locate the power supply board, look for the electolytic capacitors top that is slightly domed, replace them, they usually 1 or 4 that is bad, buy your replacement's at Radio Shack
Jun 06, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
Olevia 37 turning off for no particular reason
I suspect that the main power supply is trying to self-destruct; what you describe could be the switching power supply struggling to stay up and running. It isn't the cable company's problem.
FYI: Olevia has declared bankruptcy so you may not be able to get any help from them.
Nov 17, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia
I have a 47 a 32 and a 37 inch olevia tv. Just bought the 37 because i havent had any probs with the others. Well recently i moved my 47 inch and had it plugged into an outlet that had a one of those one into three strips plugged into the outlet and my tv kept shutting off. So i plugged it into another outlet and it worked fine so do try another outlet.
Aug 18, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT 37 HVS HDMI PORT
You need to take the unit to an authorized repair shop to have it
check and correct it , looks like the power supply section got affected by the sudden change of voltage and damaged an internal part, hope this helps , AJ
Jul 02, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia 747 won't come on
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Feb 26, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Power supply problem?
necesito comprar la fuente de alimentacion electrica de mi tv olevia lt37hvs mi correo es luis19rpm@hotmail.com
Sep 01, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
1,618 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
