Question about VuPoint DC-C210-VP Digital Camera
Will not power on
Green light comes on when hooked up to computer, new batteries installed, still will not turn on
  • anics0114 Jul 15, 2008
    the green light comes on when hooked to the computer, the batteries are new, but the camera will not come on
  • kgshurley Jul 19, 2008
    Same problem. Got camera for Christmas. Never a problem. Acknowledges USB connection with green light, but will not power on. New batteries. Blah Blah....
My camera wont turn on it only works in the computer its a new problem cause i just got the camera for christmas
Posted on Dec 30, 2007
  • 363 Answers
Is this a new problem or have you only just got the camera? Please give as much information as possible.
Posted on Sep 29, 2007
6ya staff
SOURCE:
Battery light comes on new battery and new alternator
check to make sure there is power at the large wire on the back side of the alternator, Unplug the small connector and hook up a volt meter on the dark green with orange wire. you should see 12+ volts momentarily when you turn the key to the run position. Start the vehicle and make sure there is 12 volts at that that wire. The other wire is the field control from the pcm.
Is it a new alternator? where did you purchase it?
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Nov 26, 2012 | 2000 Dodge Caravan
Toshiba Satellite m65s809 has power from adapter green light comes on but no battery lights, computer wnot turn on. will it run with on battery?
Get a new battery O.E.M version for your lap top. Remove the battery and plug it in if it starts and operates it is the battery issue. If it will not start up without the battery installed it is the power supply unit change it out. Hope this assisted you. John
Jan 28, 2011 | Toshiba Computers & Internet
I am trying to hook up to my new comp. and new internet and the lights come on for the wireless, wired and router r green then the modem light is red, what am i doing wrong
There is nothing wrong with your modem. There are modems that when you turn it on, the wireless, dsl lights are green while the power light is red then after a few seconds, the green lights disappear and the red light will turn green. After sometime green light will come back on. This means your modem is restarting and doing a self check.
If the power light stays red, then you a have a problem with your modem.
Sep 10, 2010 | Computers & Internet
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
We have bought a tom tom 910 its about threeyears old it worked at first but now it wont work at allthe green light wont come on all the time to
Try doing a device update while connected to tomtom home, if that doesnt work backup your device onto your commputer and try reinstalling the software and maps ect onto your device.
Aug 02, 2009 | Tomtom GO 910 GPS Receiver
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Mac Ibook Power supply problem
On Mac iBooks the orange light comes on when it charges the battery. Once the battery is charged it turns green. Im guessing the other powersupply was aftermarket or broken. EIther way, if it starts out green - recognizes the battery isnt full - turns orange for a while - then turns green when the battery is full, then the computer and powersupply are working perfectly. Enjoy your iBook!
Feb 27, 2009 | Apple Computers & Internet
VuPoint DC-C210-VP Digital Camera Logo
59 people viewed this question
Top VuPoint Cameras Experts
Marvin
Marvin
JonSnell Electronic
JonSnell Electronic
Are you a VuPoint Camera Expert? Answer questions, earn points and help others
