Question about Miele W2662WPS Front Load Washer
Load indicator not working
My Miele W2662 WPS has a Load % / Detergent % indicator - this does not currently work - I tried to zero the system as described in the manual by leaving the door open, turning the machine off and back on again, setting the dial to Cottons 95deg and pressing the load / detergent button until the system zeroed itself - this seemed to turn this function off! Does anybody know how to turn this function back on again.
4 Suggested Answers
SOURCE:
SOURCE: Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Posted on Nov 11, 2008
SOURCE: My towels and cottons are stiff and rough from my
Maybe you need to use a water softener? sometimes the water is very "hard" some people even have to use a water conditioning filter on the water in..
Posted on Feb 03, 2010
Jahn27
  • 1554 Answers
SOURCE: Miele 435-plus washing machine Problem: water
There's a hose or tube that goes from the dispenser cavity to the tub that is likely clogged. Small clothing can be siphoned into the hose or tube and block the water path causing it to leak out to the dispenser drawer. Locate the hose/tube port in the tub where the blockage may be located, if not, you have to remove the front panel fully access and take the hose/tube out for inspection.
Disconnect power then remove the screws attaching the top panel to the rear of the machine and slide it rearward and off. Remove the dispenser drawer then the screws securing the console to the machine cabinet. Lift the console off then remove the screws securing the front panel to the cabinet. Slightly lean the front panel forward and disconnect the door lock and switch assembly wire harness. Remove the front panel and set it it aside. The hose/tube can now be fully accessed for inspection. Reassemble the machine in reverse order of the disassembly steps.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need further advice regarding the issue stated herein.
Posted on Feb 25, 2011
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
W4840 water proof system activated how to reset
1. Unplug the washer
2. Tilt the machine forward about 45 degrees
3. Water will start pouring out from the base pan. Have some towels handy to clean up.
4. Put the machine back in its position
5. Plug it
7. You should be ready to go
Causes
- You may be using too much detergent. Try lesser amount next time.
- There is a leak. If using less detergent does not solve it and this message keeps coming back, then the leak needs to be investigated.
Dec 10, 2010 | Miele W4840 Front Load Washer
When attempting to start dishwasher load the signal F 70 come up and it wont work. Purchased 2nd Jan 2008.
F70, waterproof system activated. this means you have water in the bottom pan of the dishwasher. your miele shuts itself off and runs the drain pump continuously any time water leaking is detected. you can pull out the black plastic toe kick under the door. there is a cover panel in the center held on with two t20 screws. you can dry up the water and try to run a cycle. if it works ok, cut back on your detergent by 1/2. if it leaks again, you should probably request service from miele. if you want to try to repair it yourself, let me know and I will help you troubleshoot it further.
Nov 17, 2010 | Miele Dishwashers
Water intake alert coming on however the water is turned on. No water seems to be entering the dishwasher.
No water intake, may be a defective intake hose valve. Miele calls it, the Waterproof System hose (WPS). However, first shut off your water valve to the dishwasher; disconnect the WPS; and inspect and clean the plastic filter. If the problem persists, then replace the WPS (~$170).
Oct 17, 2010 | Miele Premier-Plus Built-in Dishwasher
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Feb 16, 2010 | Miele W2203 Front Load Washer
Soap suds on the door at the end of a wash cycle. Miele E526
With all modern front loading washers, you might find that the amount of detergent you need is much less than what is recommended by the detergent makers!
First, be sure you're using the He (High Efficiency) detergent and try using only 2 or 3 tablespoons of detergent. If you've heavily stained clothes, be sure to pre-treat them rather than adding more detergent. That should also help with the extra soap left in the clothes after a complete wash cycle.
Give this a try and adjust the detergent as needed to get the best results for your situation.
Hope you find this Very Helpful and best regard!
Sep 22, 2009 | Miele Novotronic Premier 500 Front Load...
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Miele washer-dryer
you have activated the float switch in the base of the unit due to a water leak. this could be just excess detergent or an actual leak. if you tip the unit forward with some towels in front this will drain out the water. try running again with no detergent. if it doesn't show WPS after a couple of washes then you are ok. then change your detergent.
May 31, 2008 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele W2662WPS Front Load Washer Logo
49 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Marvin
Marvin
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
