Question about Sony KP-57WS500 57" Rear Projection Television
Kp51ws500 i believe i have a convergence problem. is there a way to adjust the convergence manually or is it suggested to get a tech to do the adjustments?
    Genius:
  • 1,694 Answers
Best to get a tech to verify problem--you may need a convergence circuit repair==change the STK IC's and then check convergence.Please describe symptom as you see it,if you want more assistance.
Posted on Sep 30, 2007
How can I fix the convergence on my Sony projection tv (kp51ws500)
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustments to projection TVs are given in detail.
Apr 10, 2017 | Sony Televison & Video
Kp51ws500 Tv has double outlined colors pink and green. Tried to adjust with the flash focus and nothing happens. Is there anything else we can do. What is a hard start?
You will need to install the sony type 1 convergence repair kit which fits your model. Its available from www.tvrepairworld.com and contains the parts and the CD with repair instructions.
Jun 21, 2011 | Sony Televison & Video
I have a Sony kp51ws500 convergence problem
Required convergence repair kit for Sony KP_51WS500 is available HERE, click for more info.
Thanks.
May 21, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony tv kp51ws500. 3 colour off centered.2 conv.ics replaced componant and voltages ckecks ok.yet convergence doesnt adjust.magic focus doesnt adjust colour. whats the solution.
perfect focus is what this uses-magic focus is what it is called in the Hitachi sets.
If it is KP51ws500 did you check the two 5 amp pico fuses on the other board---the power supply board?
let me know what you find and I will help you--I have fixed hundreds of these sets.
SD TECH
Dec 16, 2009 | Sony KP-51WS500 51" Rear Projection...
How to get in convergence set up mode sony tv kp51ws500
OTHER THAN TRYING IT IN THE CUSTOMER MENU there is the tech menu.
With the set off on the original Sony remote control press:
Display, 5, Vol up and power.
The set should come on with a lot of words and numbers on screen.
With 1 OR 4 you navigate until you see PJE on the screen.
9, and then 6 on the remote will bring up the convergence grid. You will see a grid with a blinking colored cursor--if it is green do nothing--3 will allow you to change to red or blue or green. IT IS A GOOD IDEA TO CHANGE THE SET TO A UNUSED VIDEO INPUT TO MAKE IT EASY TO SEE WHAT YOU ARE DOING.
Select red with the three button and navigate with the 1 or 4 buttons--enter button will allow you to adjust. enter again will allow you to navigate with the 1 or 4 buttons-- you want to get to the middle of the screen and then with 1 or 4 buttons navigate from the center around the screen.
You will find 1 moves adjustment in one direction and 4 in another. Go all around and adjust red first. Then repeat with blue.
YOU ACTUALLY ADJUST USING THE CURSOR BUTTONS--WHEEL NEAR THE MIDDLE OF THE REMOTE--YOU WILL SEE THE CHANGES AS YOU DO THIS.
When you are done hit Muting and then enter to save adjustments.
NOTE: some of these sets require the convergence be adjusted in the 4X3 which will also adjust in the FULL--if the set has the ZOOM AND WIDE zoom you will have to repeat the adjustment again in one of those modes to adjust Zoom and Wide Zoom.
Also if you have HD connection you may have to adjust it there also--many of these sets require it to be adjusted 3 times in the three modes.
IF convergence will not adjust in any one of the picture modes you have a convergence circuit problem and need to replace the convergence chips etc.
When you are done be sure to hit Muting and then Enter to save adjustments you have made. The word Write will appear on screen in green when you press muting and then in green when you press enter--it means you have saved the adjustments.
NEVER TRY TO ADJUST GREEN!
If you have questions or need help let me know.
IF this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Sony KP-51WS500 51" Rear Projection...
The screen is just blue... apparently, the red ad green lights are blown. How do I rectify this situation? Sony rear video tv kp51ws500
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com.They have put together a kits for most models. If you don't see a kitfor your set send them a quick note and they will put one together foryou. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 29, 2009 | Sony KP-51WS500 51" Rear Projection...
KP51WS500
you need to have the tv re converged
Oct 06, 2008 | Sony KP-51WS500 51" Rear Projection...
Concave comvergence problem i believe
Unless you can solder and use a meter then yes you need to call a tech, this repair should run somewhere from $300-$500. Let me know if you need more info
Tim
Sep 09, 2008 | Sony KP-51WS510 51" Rear Projection...
PT-47WX49 47 in. Rear Projectiopn Problem:
get in to the eprom setings and see if any adjustments have changed.the service manual can be gotton at servicemanuals.net
Aug 29, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Auto Convergence not working
I'm assuming you were having picture quality problems prior to pressing the auto convergence button. If not then there could be a problem in that circuit. More likely I believe is a problem on the convergence board assembly or in the pincushion circuits. Also, check your owners manual to see if there is a manual convergence adjustment you can do.
Jan 27, 2007 | Zenith R49W36 49" Rear Projection HDTV
Sony KP-57WS500 57" Rear Projection Television Logo
93 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
