Question about Denon AVR-1707 Receiver
Denon AVR 1707
Hooked the speakers up to the receiver, turned it on but no sound, not even from the radio (antenna installed). dont understand it. display is lit and in the case of the radio, looks like the receiver has locked onto a station. any ideas, or is the receiver broken?
  • semiii Sep 30, 2007
    tried your solution (had done this before) but still does not work. also reset the microprocessor but no good.
    Brigadier General:
  • 6,966 Answers
Hi, There should be a very light thumping sound when you power off or power on the receiver. If none, then it is possible that as you posted, the receiver is broken. 3 possible areas where the receiver might be having some problem(s) are: 1. The speaker protection circuitry. This might have activated which is indicative of another possible problem(#2); 2. Your amplifiers are dead; 3. For some reason, audio muting is activated. this is normally caused by the microprocessor not detecting any intelligent audio input and mutes the audio before going into the preamp stage. Examples of this are when they FM signal is weak there are more hiss than intelligent sound. But as you posted, there seems to be a station that it has locked into and an antenna is installed. If resetting the unit and trying other signal sources such as CD player or MP3 player, or even your fingers on the positive end of an RCA plug and likewise trying the different RCA inputs and selecting the source as the case maybe, and you still do not get any sound reproduced from the speakers, then it is probably safe to say the your receiver needs some repairs. Since this involves electronic circuit diagnosis, probably soldering and replacing some components, perhaps your best bet is to seek the services of a qualified professional. Hope this be of some idea/help to you. Good luck and kind regards.
Posted on Oct 01, 2007
  • Louie  Role
    Louie Role Oct 01, 2007
    Hi again,
    It is also possible the the amplifier is not receiving any power. Normally in designs like this, there are multiple fuses installed. The amplifier section is powered by a separate high current source and is fused separately from the logic and peripheral circuitry. Should you venture opening your unit, power amplifier fuses are located very near the main power supply. In some instances, they are mounted on the PCB of the amp themselves.
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
I have a Denon AVR-1707 with a center, 2 front speakers, and surround sound back speakers. When set to FM radio, all speakers work. When set to TV, only one side speaker works. Any ideas? It worked fine...
Follow the sound back to its source. FM is internal so it can't possibly have a cabling issue.
I imagine your TV sound ultimately originates from a cable box which has a nice juicy digital output that the Denon could use. Why route audio through a TV, like the manuals tell you, when you can get it straight to the best audio device without a detour to a TV and its dubious audio electronics?
Apr 17, 2011 | Denon AVR-1707 Receiver
Trying to hook my lg tv to a denon avr-1707 receiver so i can have external speakers
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Jan 31, 2011 | Denon AVR-1707 Receiver
My denon AVR 1707 has flashing red light have disconected all speakers and it still flashes red is there anything else i can do.
Only what you can do is to bring the receiver into repair shop. The receiver has a hardware problem.
You can repair here
Jul 14, 2010 | Denon AVR-1707 Receiver
H/p only displays when I turn the Denon 1707 receiver on. Speaker A nor B turns on. How do I fix this? Thanks, Bruce Krohn
HeadPhone Only, the jack is probably dirty , the dust shorts the relay and cuts the speakers out, compressed air (or a good set of lungs) directed down the headphone jack should fix it.
Jul 05, 2010 | Denon AVR-1707 Receiver
Where do i plug in the yellow, red and white cables on the Denon avr 1707 for connection to wii
the yellow goes to the tv then you can have your audio run through the receiver for sound or you can plug in the tv audio in.
Oct 24, 2009 | Denon AVR-1707 Receiver
Denon AVR-1707 Receiver Logo
166 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
