Question about Whirlpool Calypso GVW9959K Top Load Washer
It is plugged but how Do i un plug it
Ok so I do beleave that the washer is plugged how do I unplug it. do I simply take off the back and I will see it, I am going to try that now, but if you know exacteally how please tell me
  • 290 Answers
I assume the machine is not draining. Most of the time the obstruction is in the pump itself. UNPLUG POWER CORD. THIS IS A MESSY REPAIR unless you can get the machine outside and drain the water. There are two different pump configurations on these machines. You will need to lean the machine back against the wall so you can remove the bottom panel to get to the pump. There are 3 screws holding it at front of machine. If your machine has the pump that is held on to the motor with 2 metal clips, you can remove the clips and hoses and remove pump. Look in pump inlet and outlet and see if you can see the restriction and remove it with needle nose pliers. Most of the time this type of pump is beyond help and must be replaced with the newer style. About $300 to have this done by professional. If you have the newer pump, it will be part of the motor. You can remove the hoses and three screws that hold housing to motor. Be sure you don't lose or damage rubber seal on housing. After you clean pump, clean and dry seal area and reinstall housing and hoses. It will usually seal back with no problem. You may have a restriction in sump of tub going to pump. Sometimes it can be cleaned from rear of machine, if not, the basket will have to be removed. Depending on age and condition of machine this can be simple or very expensive. If basket is frozen to basket drive, you can replace machine cheaper than replacing basket and drive.
Posted on Sep 30, 2007
SOURCE:
My sharp microwave quit working model R551zs fuse is ok
Does the faceplate light up? If it does not the face plate plug may have come loose.i have seen this on several Sharp microwaves. Simply unplug your microwave, remove two screws holding the face plate, unplug the white plug carefully and then plug it back in. Hope this helps.
Aug 24, 2018 | Sharp Microwave Ovens
Gives code F15, drum motor not working. Does fill and drain ok. Have unplugged and changed cycle with no change, drum motor not working. IS there a reset?
F15 is a motor control unit error, this can be caused by a module failure or loose wiring or multiple error codes in a cycle, try un plugging for ten minutes to reset.
Aug 17, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont drain
Check filters, drain pipe and drain pump for blockage. Make sure the pump mechanism moves freely in its housing . Un ravel any hair bands, loose cotton elastic etc. make sure to UNPLUG YOUR WASHING MACHINE BEFORE DOING ANY CHECKS. Sometime just unplugging the machine and plugging it back in again it can reset the machines program functions.
Mar 25, 2012 | Roper Washing Machines
Lost power during cycle. now I get F11 error code and it wont drain/spin
Hello
Un plug washer for a min.Plug back in,Restart wash cycle from the begining.
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Screen is back tried unplugging and re plugging doesn't work
take a pencil errasor and clean the contacts that connet to the computer. next make sur eyou turn on the on switch. beleave it or not many forgt too. if that does nto work repalce.
Dec 04, 2009 | Computers & Internet
Kenmore He2Plus Washer: Controls Locked button lites up & beeps
plug it back in and there should be a buttong somwhere toward the corner and in small lettering"un-lock/lock" hold that button for 5 secs and see if it un-locks the board. if it dont the your board might be bad....hopefully this helps
Jul 30, 2009 | Washing Machines
Microwave not coming on when plugged in
The first step is to check the fuse in the mains plug. If this is ok, one will have to remove the microwave cover (un-plugged) and check the internal fuse.
If this is ok, it's an electronic fault and likely to be expensive to repair.
If the internal fuse has failed, it's usually for a reason.
Follow the above and reply.
regards
Apr 26, 2009 | Emerson Microwave Ovens
Is there a reset button on the LG front load washer
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Feb 25, 2009 | LG WM2688H Front Load Washer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Fisher & paykel Soft Touch
Un plug the dishwasher and plug it back in.This may re set a bad control board.
May 26, 2008 | Dishwashers
Whirlpool Calypso GVW9959K Top Load Washer Logo
57 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
