Question about Cowon System iAUDIO X5L Digital Media Player
X5l no output play of mp3
My cowon x5l dont play the mp3s i have in, but the radio play
0 characters
1 Points
My cowon x7 gives a
Check the specification of your MP3 player to determine thetype of video file format it uses.Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX.If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. After video conversion then copy the videofiles to your MP3 player using the USB cable from your computer.Click on this link for instructions on converting videofiles for MP3 players :-
May 15, 2012 | Cowon X7 3 Player
Send music to Cowon D2 but when I try to play, it says no music
Your d2 must have been affected by virus which has hide your music folder so unhide the music folder
Aug 18, 2009 | Cowon System s D2 Digital Media Player
Can't hear audio book files on my d2
because audio book can be played in d2 firware 4.58 just go and download the firmware from cowon site and update it then u will be able to play audio book
Jun 26, 2009 | Cowon System Cowon D2 Digital Media Player
Change OS to English
May 13, 2009 | Cowon System iAUDIO X5L Digital Media...
I need help
UM i have a 238 and they dont have a radio or voice recorder on it ... just plays mp3s .... should say right under screen mp3 digital player ... if it says radio on it somewher it must be differnt model  hope this helps
Jan 17, 2009 | GPX MW-238B MP3 Player
Cowon A3 display 'unsupported codec' when VOB file is played.
The Problem is solved with the Firmware - Version 1.23 all newer Firmware can't play VOBs, because there is a License - Problem
Nov 07, 2008 | Cowon System MP3 & Digital Media Players
Earphone socket on the Cowon iAudio XL5 30 gig.
try to send it back to Cowon company, or try to solder the joints, inside the mp3 player most likely it is at the top of the mp3 player, but know what your doing otherwise it can be destroyed, if you don't repair it the right way
Apr 10, 2008 | Cowon System iAUDIO X5 MP3 Player
Yes it does, but the screen is small and the playback rate (15 frames per second) is slow for a fast action movie.
If you really want a video player with the same audio quality as the X5L, then take a look at the A2 from Cowon.
Apr 08, 2008 | Cowon System iAUDIO X5L Digital Media...
If your truck radio is a factory cd player, the easiest way to play mp3 through it is probably to burn your mp3s to CD as an Audio CD. There are aftermarket car stereos that can play mp3s directly, whether burned straight to CD, on a USB stick or via built-in storage.
Feb 17, 2008 | MP3 & Digital Media Players
Sansa e140 just need some help with menus
When you power on your MP3 player it will go to the FM radio. 1. Press menu.
2. Go down once and you'll be on "Mode". Press the right button to access the mode menu.
3. You either press the enter button after accessing the menu or go down to select Playback mode (I forget which one it is).
Good Luck!
Dec 26, 2007 | SanDisk Sansa e140 MP3 Player
Cowon System iAUDIO X5L Digital Media Player Logo
15 people viewed this question
Top Cowon System MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Cowon System MP3 and Digital Media Player Expert? Answer questions, earn points and help others
