Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Weird Rapid Metallic Popping Sound
While watching tv the other day, the unit unexpectedly went out, after which there was an unusual rapid metallic popping sound, similar to the sound one hears when turning on flourescent lights in an office (or wherever). The lamp indicator light on the front of the unit never lit up to indicate a bad lamp (shouldn't it do this before the lamp blows?). Now, when trying to turn the unit on, all we hear is the rapid popping sound -- there is no audio or video. I'm not sure if the lamp is busted, or the ballast. Any ideas? Is the rapid popping sound normal for a burnt out lamp?
  • 4 more comments
  • OMMBoy Sep 29, 2007
    Hi! Me again! Just wanted to change the "popping" sound to more of a "plinking" sound. That's all. Thanks for any help you are able to provide!
  • OMMBoy Oct 08, 2007
    After one week of waiting for someone to answer my questions, I've decided to take it upon myself to fix the tv. I removed the front panel and pulled the lamp out. Upon inspection, the lamp was definitely busted with evidence of glass shards within the reflector housing. I've deduced that the "plinking" noise came from the ballast, which was trying to start the lamp. How did I arrive at this conclusion? At my job, we use UV spot-curing lamps. When one of these lamps burns out, the UV-unit continually attempts to ignite the lamp by supplying a 3000V arc to the lamp until it ignites. It does this in rapid succession. The plinking sound from the tv unit is nearly identical (albeit a bit slower) to the sound from the UV-unit. All I have to do now is wait for the replacement lamp to arrive...
    I've resolved the problem on my own (see all comments to original posting). However, I still don't know why the lamp indicator LED never lit up...
  • OMMBoy Oct 15, 2007
    Solved it myself, thank you very much!
  • OMMBoy Dec 01, 2007
    No, the sound actually came from the front of the set where the bulb is located (just left of center). What does an arc welder sound like? Sorry, can't comment on that. But it does sound like you might have the same problem, except that you're still getting audio. If you're confident enough, pop off the front panel and extract the bulb (procedure is outlined in the manual) -- you'll know if it's broken just by looking at it. Good luck!
    No, the sound came from the front of the unit, just left of center. What does an arc welder sound like? Sorry, can't comment on that. If you're confident enough, pop off the front panel and extract the bulb -- you'll know if it's blown (procedure for removing the front panel is in the owner's manual). Good luck!
I think i have the same problem, but i can get audio still. did the poping plinking sound come from the inside back panel of your TV? it sounded almost like a arc wielding noise?
Posted on Dec 01, 2007
SOURCE:
Rapid loud popping sound for 3 to 4 seconds before printing
The popping noise is coming from the carriage belt jumping on the drive motor cog. It indicates that the cartridge carriage is jamming while the motor keeps spinning. It may be due to a wedge of paper at either end of the carriage bar (horizontal rod) or it may be due to a failing main board circuit.
Jan 07, 2018 | HP Photosmart C3180 All-In-One InkJet...
Apple tv unit ,rapid falshing of power light
Hi Doug
Take a look here for what the lights mean:
Apple TV About the status light
Andrew
Jan 07, 2014 | Computers & Internet
Rapid clicking sound in engine and metallic debris collecting on base of engine covers
That's the sound of the lifters grinding themselves to pieces. That engine will be terminal if run in that condition.
Dec 20, 2012 | Cars & Trucks
TV will not turn on
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
Nov 21, 2012 | Panasonic PT-44LCX65 Television
Phillips TV clicking sound, then cuts off
The problem of that is a loose solder on the board..
Aug 07, 2009 | Philips 52PFL7422D/37 TV
Tv popping sound when turned on
It sounds like you are hearing arcing from the FBT. The FBT should be replaced before it causes something else to fail.
Jan 08, 2009 | RCA Universal Remote Control
Delonghi TRD715T
Does it sound like oil bubbles? Sometimes when an oil heater is heating up you can hear the pop sound of the oil heating.
Feb 15, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Sound cuts out every so often when using Coax Digital In
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
Sony KDF-50WE655
It sounds like the lamp is definitly bad.
Look at it and more than likely it is broken.
The lamp is located in the front of the set. The bottom front is a cover that has a dial on each side of the back of the sets that can be turned by hand (counter clockwise) holding the front panel in place.
There is a metal strip that is holding a door in place and can be removed.
The lamp is being held in place by a screw that needs to be removed with an allen wrench.
There are several places that you can buy lamps online.
This is a link that this site advertises that has do it yourself instructions:
www.AMatterOfFax.com Reply to this post if you have any questions and I will respond.
Dec 01, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
