Question about Dell 942 All-In-One InkJet Printer
Dell 942 all in one printer reinstalls itself
Dell all in one printer makes a copy of itself every time i try to print a page. we i delete the copy and try to print it does the same thing. i have used the copy to print sometimes,and other time i have to use the orginal.
    Problem Solver:
Not sure what your asking here. Please restate your problem and give all the details. The more the better so we may understand whats going on.
Posted on Nov 04, 2007
SOURCE:
My photo 926 is printing black horizontal lines just over the graphics and letters...This started when I tried to reinstall my operating system. I reinstalled my printer drives...but to no avail. I've...
Chances are that if it started when you attempted to reinstall your OS, it is most likely not a hardware issue. Try deleting/uninstalling the printer and reinstalling from the original disks or from the Dell website. Make sure to use the correct version of the print driver software for your OS.
Check out this link if you need to download the software/drivers for your printer:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_ALL_A942&os=WW1&osl=en&catid=&impid=
Oct 21, 2010 | Dell 942 All-In-One InkJet Printer
Have a dell 942 AIO. graphics in grey seem to print purple
what OS are u using ?
U may will have to unistall the driver Again ( make sure that the printer is unplugged) . run Patch .. ( Available at support.dell.com )
Reinstall the Printer drivers again ( downloading from Dell Website .. install them ( make sure that the cable is connected only when Prompted ) )
This should resolve the Problem
Mar 20, 2010 | Dell 942 All-In-One InkJet Printer
Dell all-in-one 942 printer
hi tnstiger00,
you can try these steps:
1.Check if the firewall is blocking any printer services 2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode 3.Disable all the firewalls 4.Uninstall the printer driver and software 5.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2 HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3 Optional*** 6.Delete any non default items under the ff keys: Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED HKLM\System\CurrentControlSet\Control\Print\Monitors HKLM\System\CurrentControlSet001\Control\Print\Monitors Default items are as follows: AppleTalk Printing Devices BJ Language Monitor Local Port PJL Language Monitor Standard TCP/IP Port USB Monitor Windows NT FAx Monitor ***** 7.Delete any items under the ff keys: HKLM\System\CurrentControlSet\Control\Print\Printers HKLM\System\CurrentControlSet001\Control\Print\Printers 8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista) Ensure there are no documents in queue. Disconnect printer’s USB cable. Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility. From the start search box type spool and press . The spool folder located at c:\windows\system32\spool opens. Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup. Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup. 9.Restart the computer. 10.Check th services status Start-Run- Type Services.msc and Click on Open You will see long list of services You need to make sure following 4 Services are set to Automatically start Remote Procedure Call RPC Remote Procedure Call RPC Locater LexBce Server Print Spooler 11.Reinstall the latest printer driver
just update me if you're still having issues with the printer.
Oct 14, 2009 | Dell 942 All-In-One InkJet Printer
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
Optional***
BJ Language Monitor
Local Port
USB Monitor
LexBce Server
Print Spooler
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
No longer feeds the paper correctly when trying to print. It seems to feed the paper at an angle. I can hand feed one page at a time but still isn't straight. What can I do?
Please try to reinstall the your printer driver. Usually the driver is the one which malfunctions.
Good luck.
~regards,
Jegan
Jun 03, 2009 | Dell Office Equipment & Supplies
Dell AIO 942 printing problem
Hi Lei,
You may try to check on the printing settings. You may need to check also if it is defaulting to all. You may try printing it by pages. If the issue persist then there is something wrong with the settings. You may also try to uninstall and reinstall the printer software if the issue persist.
Keep me posted.
Thanks,
Jeff
Oct 11, 2008 | Dell 942 All-In-One InkJet Printer
Dell AIO 942 Wont' Scan
try uninstalling & reinstalling the drivers....tht wld fix the issue...
Apr 16, 2008 | Dell 942 All-In-One InkJet Printer
Dell printer
You can try cleaning the feed rollers and manually clean the ink cartridge carrier contacts. The issue may also be the encoder which is a narrow band of transparent plastic behind the ink cartridge carriers. Try to clean this. Be careful as this can break easily.
Nov 27, 2007 | Dell 942 All-In-One InkJet Printer
My dell 942 aio is waco
Suggest you completely remove the printer from your system. The shut down the system, restart and reinstal the software that came with the printer. If it install completely with no problems you should be Ok to go. If not write back and with the info you can give on the removal the first time if it went ok and the reinstalation it it went OK. Also with the printer completly disconnected from your PC just plug the power cord into the wall and then put something on the scanner screen and see if you can make a copy of it by using the copy button. You should be able to make a black or color copy without your Pc hooked up.
Oct 20, 2007 | Dell 942 All-In-One InkJet Printer
Dell 942 All-In-One InkJet Printer Logo
24 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
