SOURCE: My amana side-by-side SQD26V is
first off make sure that the drain on under the coil is cleared, then when the ice is gone and you turn the unit back on the coil should first get good and cold before the fan tries to come on . you will have to temporarly put the cover over the coil to do this. let it run until there's good frost on the coil and then the fan should come back on. that would rule out the motor,and the thermostat. thanks for unsing FIxYa
SOURCE: My Amana Side by Side refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Is it a frost build up or ... ICE.. and IF ice where is it at?
If frost you have a defrost problem
