Microwave Ovens Logo
r
rathnakarkotian Posted on Oct 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gw73vd model oven not heating - Samsung Microwave Ovens
ernesto cuadra
Level 3:
Top Expert:
  • Samsung Master 12,223 Answers
  • Posted on Oct 26, 2013
ernesto cuadra
Samsung Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4080480
Points
34431
Please make this steps and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
How do I fix the oven when it no longer heats food but all other features of the oven work fine?
Could be a burnt out fuse but most likely its the heating coil is burnt out.
Gw73vd oven not heating all light motor working
test this steps and fix it. God bless you
Frigidaire Gallery stovetop model number LGEF3031KMB Oven will not heat up to temperature. Oven, Pre-heat lights will come on, but the oven will not reach any temperature set.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
1helpful
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Kenmore microwave model 721.80033700 won't heat
heatman101
My microwave has stopped heating up! model #721.80043700 anybody having this problem? Do you know how to fix it?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ytu53w
4helpful
In model spacemaker xl1800 no heating but all
heatman101
gfj
Oven humms and doesn't heat anymore....
if you say 'seems like common problem with this model' then just replace it and get another good model.
it gives peace in long run.
Intermiting heat
heatman101
7r66
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
