Cornish - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Mr. Salomon,
Being one person (two, actually, counting Kerry Thalmann) who _has_ tested and
_published_ findings HEAD to HEAD against other manufacturer's lenses I can say the
difference IS NOT VERY OBVIOUS!!!
Check it out at:
http://www.hevanet.com/cperez/ testing.html In case you don't have the time to go visit that site you might be interested to
note that at f/22 135mm lenses tested the same or very similarly. Kerry and I
tested two Kodak Wide Field Ektars, a couple Nikkor 135 W's and one of your much
vaunted APO Sironar-S.
When I read the results all I have as a reference is a number and an f-stop. I
don't know which lens I'm reading. This is done intentionally so I WILL NOT
influence the test results. The entire test would be invalid if I were to "fudge"
a reading on, say, a Congo lens vs. an Angulon.
Testing one lens fails to prove the entire lot as good or bad. However, given the
growing list of lenses that Kerry and I have so far tested I feel confident our
results will be matched in many additional cases.
Your Rodenstock APO Sironar-S _is_ a fine lens. Don't get me wrong. Please.
HOWEVER, there's the matter of a little 135mm Kodak Wide Field Ektar that
I personally own that tests better at f/11 and f/16 than the APO Sironar...
If you would care to call me and talk about this, my number is found below.
Best Regards,
Christopher M Perez - Engineer IV
Email - Christopher.M.Pe @TEK.COM
Tektronix, Inc., Video Network Displays(VND)
phone - (503) 627-4767 ****************************** fax - (503) 627-1137
