Question about Fuji FinePix E550 Digital Camera
Reversion to defaault settings
3 times my E550 has reverted to the factory default settings. can someone please help me?
  • myersol1936 Oct 27, 2007
    where is the memory buttoh for this camera?
I read that if you hold the memory button down it resets the camera to factory settings. Could you be doing this inadvertently? Probably not your answer, but it's worth a shot?
Posted on Oct 27, 2007
SOURCE:
How i reset a lgmn270 from metro
1. Touch Menu
2. Touch Settings
3. Touch Phone Settings and Security
4. Enter the four-digit Lock Code
5. Touch Reset Default
6. Read the displayed message and touch OK to continue.
7. A message will pop up that says "All settings will revert to factory default." Select Revert/ Cancel
8. Enter your lock code to confirm your selection.
May 24, 2013 | Cell Phones
Hard reset
You can reset and restore the factory default settings of your LG Attune UN270 mobile phone by following below instructions:
  • Touch Phone Settings and Security.
  • Enter the four-digit Lock Code.
  • Touch Master Reset.
  • Touch OK
  • A message will pop up that says "All settings will revert to factory default."
  • Touch Revert or Cancel.
  • If you touch Revert, enter the four-digit Lock Code. The phone returns to the configuration default.
May 22, 2013 | LG Attune
Purchased refurbished phones and they do not have the Factory Defaulted Admin Password. How to reset the Polycom Soundpoint IP501 to Factory Default Admin Password?!?
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Apr 01, 2011 | Polycom SoundPoint IP 501 IP Phone
How to format nokia xpress music????? pls help me....
Soft Reset The reset will restore all the phone's settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory, including take off your memory card.
  1. Switch off the phone.
  2. Press GREEN + RED + CAMERA + ON simultaneously until you see the "Select Country" option.
Note:
  1. The default password is 12345. You need to press and hold the key until the number appear.
  2. Please do not confuse "revert to factory settings" with soft reset. "Revert to factory settings" can be achieved from Menu > Settings > Phone > Phone mgmt. > Factory settings or *#7870# code, and will only restore the phone to its factory setting without deleting data.
If this answer helpful RATE please
Jan 29, 2011 | Nokia 5800 XpressMusic Smartphone
I forget my nokia 5800 password. pls tell me
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
Note:
Nov 10, 2010 | Computers & Internet
If i revert back to my factory settings on my netopia router will this impact my at&t settings? I'm just trying to let someone use our wireless access and have misplaced the login info
Restoring the router to factory default will have impact on AT&T settings provided if you not made note of the setting details. However its adviced to call up AT&T and make a note of the settings before going for factory defaults.
May 09, 2010 | Computers & Internet
My Starview channels have gone as well, free view ok, 17-7-09
why did u change default settings...use defaault settings until u recieve channels then u can tweak it out for personal settings...but be caeful what u tweak out...because it sounds good to u may not be correct settings for ur GTRom
Jul 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Factory default reversion
Sounds like you have a poor connection to the batteries. If you take the batteries out, the settings all revert. Clean off the metal pieces which connect to the batteries with a dry abrasive substance. Good luck.
Sep 30, 2007 | Fuji FinePix E550 Digital Camera
Factoryvdefault settings
If you take the batteries out, the settings all revert. If you leave it open too long while changing the batteries, they revert. You might also be developing a poor connection to the batteries. IClean off the metal pieces which connect to the batteries with a dry abrasive substance. Good luck.
Sep 29, 2007 | Fuji FinePix E550 Digital Camera
PocketPC e570, Is there an opportunity to set it back to factory default?
you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
Sep 11, 2005 | Toshiba Genio e550
Fuji FinePix E550 Digital Camera Logo
246 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
