Question about Alpine MRP-M450 Car Audio Amplifier
The light on top on my MRP-M450 blinks and the amp doesn't work
I just hooked this up in my car...I had it in my truck previously with a dual voice voil sub at 2 ohm load, and though it's a different sub in the car it's still a DVC at 2 ohm load. I literally just wired it, and turned the stereo on. It started working fine, and I was adjusting the LP filter, Bass EQ and Gain knobs, and there was a popping sound and the sub cut out. When this happened the power light started blinking too...it's lit but it just seems like an intermittent blink or cutout of light. I didn't have the stereo turned up nearly as loud as I previously have in my truck, so I'm not really sure what I could have done wrong. I took the back cover off of the amp and nothing seems burned...what else can I check?
  • MikeOD Oct 01, 2007
    The sub is fine, I hooked up my roomates Kicker amp and the sub sounds great. My multimeter shows it at 2.1 ohms...thats pretty close to the 2 it's suppossed to be, and if I push on the cone it reacts normaly (resistance goes way up and down as the cone moves).
    What should I check next? I appreciate the help.
    Problem Solver:
  • 6 Answers
Well if you took off the cover on the amp and nothing seems to be burn't, check the voice coils on the sub. It's possible the voice coils have separated and is causing the amp to short it self out due to ground error. If that doesn't help let me know and I'll tell you the next step.
Posted on Oct 01, 2007
  • Patrick Craig Nov 19, 2007
    There are also the internal crossovers inside the amp. Use your meter and check and see if the resistance is the same on each one of the prongs. They are small black boxs that are attached to the board it self usually on the side on the board held down with metal plates. If the resistance is not the same they are bad.
SOURCE:
When the bass cut on the speakers cut off
220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
the amplifier may be over-driven. are there red protection lights coming on the front panel? Or a loose wire - power, ground, or speaker.
Dec 18, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amp light flickering
do you have a capacitor its like an extra battery, if you turn the volume way up with cvr's pullin big power, it cuts out because theres not a steady flow of power.... hope this helps
Jun 30, 2008 | Alpine MRP-M450 Car Audio Amplifier
Power turns on briefly
Sounds like a protection problem. A relay may be stuck, or there really may be an internal problem you cannot see. Take it to a shop to have it bench tested independent of your vehicle.
May 20, 2008 | Alpine MRP-M450 Car Audio Amplifier
Not enough bass
its prolly the deck, did you try turning the alpine's input gain controls up...
its not the wiring, if the wiring was insuficient, it would just melt...
you might also see if you could adjust the bass frequencies or crossover frequency, the crv might just have a different resonant frequency then the rav 4
May 16, 2008 | Alpine MRP-M450 Car Audio Amplifier
My Alpine m450 amp light is on but no sound
make sure your RCA's are plugged into the input and not the pass through
Mar 28, 2008 | Alpine MRP-M450 Car Audio Amplifier
Amp light is on but doesn't put anything out to my subs
if you are sure its the amp. the problem is internal. but if your not sure, try a different stereo or source of sound to the inputs of the amp. if there is still no sound than it is the amplifier and it could be a number of things.
Jan 07, 2008 | Alpine MRP-M450 Car Audio Amplifier
MRP-M450 puts out no sound to the subs
The amplifier may be overloaded, check to see if it can handle 4 OHM loads and 2 OHM loads. if it turns off at high volume the amp may be overloaded. if so try a 8 OHM load. if it still turns off it may be an internal problem.
Jan 07, 2008 | Alpine MRP-M650 Car Audio Amplifier
Just died out..
Have you determined if the problem is with the amplifier or the subwoofer?
Have you checked the wiring to make sure that there are no loose connections?
Oct 18, 2007 | Alpine MRP-M450 Car Audio Amplifier
Amp not working
my friend your amp could be getting power that does not mean that it is working.the power only goes to certain point but because your regulator or other related component is defected your amp power supply will not work until the defect is corrected.take it to a tech and have your set repaired.good luck.
Jun 11, 2007 | Alpine MRP-M450 Car Audio Amplifier
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Alpine MRP-M450 Car Audio Amplifier Logo
155 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
