Question about Kenwood Excelon KVT-915DVD Car DVD Player
Location of fuse
My car system stop working and I think I have traced the problem to my kenwood 5-1 dsp control in dash touch panel wide tv hide away unit. Need to find out if it has a fuse or a reset button,if so where is it located.
    Champion:
  • 227 Answers
Take the whole thing out and bench test it. You will know where the problem is and save alot of guessing times. Goodluck.
Posted on Mar 08, 2008
SOURCE:
2004 GMC Envoy XUV (SLE pkg). AC will blow through EVERY vent EXCEPT the front dash vents. Dealer says entire dash has to come off to dx the prob and quotes exorbitant labor costs. Help!
There are two possible problems, a stuck blend door (this common) or the door controller has lost synchronization. The first requires disassembly of the dash and the second can be done with the following procedure'
Pull the HVAC-B (#36) fuse for 30 seconds (located in the rear fuse panel under the seat), then put it back in. Then turn the ignition switch to RUN (no need to start the engine). Don't touch ANY controls for 90 seconds. I don't think it matters what position the controls are in, but some people think it works better if you have the HVAC system turned off. After 90 seconds, the actuators have gone through their paces, the controller has new memory data on the end stops of the rotation of each actuator, and you might be good to go
Jun 11, 2010 | 2004 GMC Envoy
My 2004 gmc envoy loses engine pressure when i have the air conditioner or the heater on. Also, the air conditioner will not blow out the dash vents but blows out the floor and defrost just fine. Autozone...
Don't know what you mean by engine losing pressure, but as far as the air not coming out of the correct vents, try the following;
Pull the HVAC-B (#36) fuse for 30 seconds (located in rear fuse panel, under seat), then put it back in. Then turn the ignition switch to RUN (no need to start the engine). Don't touch ANY controls for 90 seconds. I don't think it matters what position the controls are in, but some people think it works better if you have the HVAC system turned off. After 90 seconds, the actuators have gone through their paces, the controller has new memory data on the end stops of the rotation of each actuator, and you might be good to go
Jun 06, 2010 | 2004 GMC Envoy
Cruise control quit working, so where should I check. I would like to know about the wires and fuses and where to trace them down.
The 1994-95 Chrysler Minivans have four electrical panels/fuse boxes.:
  1. Fuse Block Panel (In Dash)
  2. Relay Block (In Dash)
  3. Micro Relay Block (In Dash)
  4. Power Distribution Center (Underhood)
Fuse block is located on left side of instrument panel, behind access door. Speed (cruise) control fuse is No. 14.
Note: If you have an airbag light on your dash litup, it might be something called a clockspring, which you'll have to take to the dealership/garage to get fixed. (Dealership is probably your best bet)
Hope this helps! :)
Oct 20, 2009 | 1994 Plymouth Voyager
Trying to find the fuse for the power mirrors/cig.lighter
Subaru is funny about hiding their fuse boxes. Yes, they are sometimes located inside the vehicle behind sliding panels beside the steering column. Check both panels by your feet and under the dash by the steering column.
Aug 04, 2009 | 2000 Subaru Outback
Dash lights not working on 95 eldorado looking for fuse panel
If it is a digital dash you need to replace the central control module located above the gas pedal. If it is not check in the glove box for the fuse panel caddys are known for hiding the fuse boxes in there.
Apr 24, 2009 | 1995 Cadillac Eldorado
Aftermarket Stereo connection
hi there
if you matched all the wires from the harness to the kenwood deck and its not working don't worry you just missed the last step........(all wires attached that a colour coded connected)
simply turn your car on.........now on the front of the kenwood deck there is a SOURCE button with all units it could be a (S, SRC, Power) hold the source button down till your kenwood unit powers up ..........if your unit still doesn't work check the fuse on back of kenwood unit should be a 10a fuse (blue) if the fuse is fine put the unit back in dash..........now check the fuse panel on driver side dash with the door open you will see this panel pull it off (some describe the fuse panel as looking like an air vent but its not its a handle to open) now on the panel that you just pulled off there is a fuse diagram on the inside look at it find radio fuse it will be a (blue fuse) located in the top row of fuses check it if blown replace and unit should work.............if this doesn't solve the issue than its a (sneaky) fuse not to many people know about if you pop the hood of your car there is a black plastic panel located just below the battery pins and just above the driver head light (usually black box with yellow writing on it......in this there are mini fuses check all of them do not touch the black relays in there just the small tiny fuses the fuse you will look at should be yellow 20a (this fuse is closest to engine and comes after the abs relay if you look inside the lid you took off it will have fuse locations cant remember which one it is for sure but check them..........now see if your kenwood unit powers up if not the last option is to ground to the black wire from back of kenwood unit to metal frame.............this last part is also done if your unit does power on but your car lights don't work if this happens ground the kenwood unit to the frame of car and open up fuse panel on driver side dash replace the blown fuse for lights or radio (make sure the kenwood unit is grounded to the frame before replacing the fuse in dash panel............if this doesnt help you than i would assume the kenwood deck needs to be repaired by kenwood.......
good luck
hope i was able to help and sorry this list is so long
Feb 26, 2009 | Car Audio & Video
Heat works on the front and the back only works when I use the front controls to turn on heater.The back Heater control panel wont turn the heat on for thr back.but still blos hot air when turned on only...
Here's what the system looks like. left rear panel
please rate as fixya if this solves your issue
Check fuse #7, 5 amp dash fuse panel
check fuse # 13, 30 amp in power dist. box under hood I think
check auxilaiary a/c relay in RPO Relay box (rear floor panel)
check fuse #23, 10 amp in dash fuse panel
Feb 26, 2009 | 1997 Ford Expedition
Kenwood kvt817 dvd player says
Same thing happened to me on 1 that I installed. There is a long molex cable on back of the head unit that goes to a tunr/amplifiwe usually mounted under the seat. This is the ontroll brain. It is either non existant, or you need to plug it back in behind the stereo. Mine was the same way,mounted in a Ford Escape, it somehow vibrated out! Go figure. Hopefully this silves it. Let me know.
Larry T
Winona Lake IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood Excelon KVT-915DVD Car DVD Player Logo
61 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
