Question about Acer Aspire 3100-1405 Notebook
Replace keyboard for acer 3100
My parrots took all but 12 keys off/ I bought a new keyboard but don't know how to get the old one off. any help would be great. thank you
  • 3 more comments
  • debbie williamson Sep 29, 2007
    my parrots are large, they broke them in many pieces.
    I dont know what lugs are or where they are on the computer
  • debbie williamson Sep 30, 2007
    I am still trying. So far I can't get a driver under it.
  • debbie williamson Oct 03, 2007
    It will not lift at the points you show.
  • debbie williamson Oct 04, 2007
    Thank you for your help. I removed the screws and replaced it. Thanks again
    Sergeant:
  • 457 Answers
On your laptop there should be two identical lugs apart from each other. Just gently prize them out all the way around the keyboard. You'll see a couple of screws securing the the keyboard loosen those and withdraw the old keybord. BE EXTRA careful when disengaging the connection to the laptop. A paper looking connection dont force it out gently ease it and replace it the same way. good luck .. hope you come back here and let me know how you got on most people get what they want and run!!! thats life
Posted on Sep 29, 2007
  • 1 more comment
  • Peter Hirawani
    Peter Hirawani Sep 29, 2007
    You know you can just replace the keys your parrots took off...... you will see how they go on. Why if you still have the old keys they must be ok just click them back in place press topwards down and gently press them in place you take them out the same way pretty hard to break. That may be easier for you?
  • Peter Hirawani
    See in this picture where I placed the black squares is where there should be a place to lever a flat screw driver to remove the edging around the keyboard.
  • Peter Hirawani
    Peter Hirawani Oct 04, 2007
    Then dont go any further you will have to take it apart to fit keyboard by removing all the screws from the bottom.
Just a note - this site helped a bunch. I was looking up how to remove my keyboard so I can clean it real well (I'm OCD that way). Thanks!
Posted on Feb 12, 2008
SOURCE:
Got a car with ck 3100 parrot fitted and can't get it to work with nokia c 5 as no instructions came with it
http://www.parrot.com/fr/support/guidesutilisateur/parrot-ck3100_user-guide_en-fr-es-de-it-nl-pr.pdf
Above is a link to the instruction manual. Try deleting any old phones from the paired devices menu, this way it should make room for new pairings. If this fails then you may need new software in the Parrot. You can do this yourself but you will need a Laptop with Bluetooth, then download the update manger from Parrot web site.
Dan
Nov 07, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Cannot connect new Sony Ericsson to parrot C K 3100 it worked perfectly on my old phone still using the same sim card but i am getting a message saying connectivity failed
try deleting all the old phones from the parrots paired devices, then try again passcode is 1234. if this still dont work you may need a software update on the parrot.
Nov 13, 2010 | Sony Ericsson J220a Cellular Phone
Hi I cannot pair my new phone by bluetooth My new
try deleting some of the paried devices from the settings menu to make room for a new phone.
Dec 27, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Unable to use phone book contacts between Nokia 5800 and Parrot 3100
You need to check that both the 3100 and the 5800 are using the latest software. There were problems with the older software but they have been resolved.
On the 5800: Settings>Phone>Phone mgmt.>Device updates>Options>Check for updates (Assumes your 5800 has a working internet connection). Othewise use software updates from Nokia PCsuite.
For the 3100: Download the software update tool from www.parrot.com to a bluetooth enabled notebook. Run the update tool and just follow the instructions. If you don't have wireless internet on your notebook, run the update tool first while connected to the net to download the update files before taking the notebook into the car. The 3100 must be in software update mode before you connect the notebook via bluetooth. Settings>Advanced settings>Software Update>Activate.
I found that it took a couple of attempts to get the connection to work, but once it was made the update completed fine. The 3100 then resets itself and you need to pair the 5800 again. Once it's paired, the contacts will synchronise.
I did this about 30 minutes ago, so I know it works.
Good luck
Nov 08, 2009 | Parrot Hands-Free Car Kit with LCD Display...
Acer Aspire One A0A150 keyboard issue,
Sounds to be you just got a faulty keyboard from HongKong, if your old keyboard works except the the Z and the new keyboard works only with function keys, then it sounds to be that the new keyboard is not ment for your laptop. if anything you should of had the same problems as your old keyboard. try using a USB keyboard.
Aug 17, 2009 | Acer Aspire One AOA150-1983 Notebook PC
How to dismount a keyboard
the service manual is her:
http://rapidshare.com/files/100460808/Acer_Aspire_5110-5100-3100.rar
Thanks for using fixya…good luck and don’t forget to rate this…
cheers
Jan 12, 2009 | HP Pavilion dv2000t Notebook
Parrot 3100 LCD Phone book problem
go into phone book, select mark all then send as a business card to parrot.
Jun 15, 2008 | Parrot Hands-Free Car Kit with LCD Display...
Parrot 3100 pairing with blackberry 8310
You have too many phones paired in the Parrot. Delete some of the phones from your parrot and you will be fixed. I had same issue
Apr 19, 2008 | Lands Phones
Replacing the keyboard
did you try replacing the key? it should just snap on...
May 03, 2007 | Acer ASPIRE 9504WSMi Notebook
Acer Aspire 3100-1405 Notebook Logo
1,085 people viewed this question
Ekse
Alun Cox
