Question about GE JE1660 Microwave Oven
GE profile JE1660WB01
I have a GE microwave ser #ZV905893s. I does not heat. It makes a loud humming sound when turn on. I think it is on the list of defective mag. Can you help ? Have a good day. Dan
  • 3 more comments
  • jhoward9 Jan 01, 2008
    I think the High Voltage Diode is bad. I've removed it. Where can I quickly get another one? It is a 1.0uF It shows some resistance compared to complete open.
  • Anonymous Mar 08, 2008
    GE JE1660WB002. Appears to be working, but makes a loud humming noise, won't heat, and a burning aroma.
  • schg Nov 30, 2008
    Unit makes buzzing noise, does not heat food, though hums and turntable rotates. Purchased this for new home in Dec. 2002. Previous GE microwave was still going strong after 20 years when I sold it with previous home.
  • carlossales6 Dec 11, 2008
    Microwave started humming and doesn't work... any ideas on how to fix?
  • sandydcheeks Jan 15, 2009
    Mine just started with the same problem yesterday!!! Tech came out today, replaced the HV Diode, Capacitator...still humming!!! Now needs to replace the magnetron tube...no way!!! The cost of parts/labor for the repair, for an 8 year old microwave, would be more than purchasing a new. Total repairs would have been $364, new GE PEB2060 + Trim Kit = $335
    Champion:
  • 225 Answers
May be megnetron or high voltage circuit ..
Posted on Oct 01, 2007
SOURCE:
Runs but has loud humming sound. Does not heat. Turntable, timer and lights work.
The diode that connects to the capacitor needs to be replaced. Once its replaced microwave will begin to heat again. (If it wasn't heating and wasn't making a humming noise, then your magnetron would need to be replaced). If you are thinking of doing it yourself and need instructions, i'll be glad to help.
Feb 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is making a loud humming noise when it is on and it isn't heating. It also has a burning smell. We had this microwave repaired replacing the magnetron and diode in Jan. 2006.
sounds like same problem again.... the magnetron is what does the heating and if the display is working and just humming sounds like the mag is not coming on .... could be the capacitor but most likely the magnetron again..... i am a appliance /heating and air company out of texas we work on these things everyday and is very common problem... thanks a/c and heating unlimited good luck
Dec 31, 2010 | Jenn-Air JMC7000 Microwave Oven
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
NO HEAT IN "OTC" GE MICROWAVE
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms ("no heat"), as well as the answers to these questions:
- When you try to microwave are the inside light, internal cooling fan and turntable all working?
- Is there any unusual noise or is it louder or quieter than normal?
We have a sound clip here of what a microwave should sound like when the cooling fan and high voltage section are working.
(A loud buzz, hum, or groan is usually a shorted high voltage rectifier diode, but a sound like gurgling into an empty coffee mug is one symptom of a failed magnetron, and yet the mag can be bad without that sound.)
Nov 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1850CH06 microwave no heat with loud humming sound
With the details you described, the high voltage diode might be shorted( usually HVR 1X). It is connected from the Capacitor and the chassis, or else the capacitor is the one at fault,but not common .
Aug 29, 2009 | GE JVM1850 1000 Watts Microwave Oven
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
Jul 16, 2009 | Microwave Ovens
Blows the 20amp fuse when the heat is turned on
It has a short. Its likely the power $5 power diode.
It has to be checked first if its good then the mag tube may be bad.
Its likely the diode. You can test it by removing it and using a ohm meter to test it. Voltage should only flow 1 way if it flows both ways its shorted.
Jan 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JE1660 Microwave Oven Logo
576 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
