Question about Hotpoint HSS25GFP Side by Side Refrigerator
Not cooling right
The bottom of the freezer will freeze fine but the top of freezer wont. we put in a new fan motor but it didnt help.
  • 1 more comment
  • mistyd Sep 29, 2007
    weve left it on for 3 hours with the new fan motor on and the fan doesnt kick on yet.
  • carmandan Dec 03, 2007
    put a new fan in and still will not run
  • Anonymous Jan 18, 2009
    Same problem. My fridge is a GE GSS25JEPABB side by side but the control board is the same WR55X10174 part number. Bottom freezes - top is warm. I haven't seen the fan spin. I haven't tried replacing it yet but it sounds like the control board is the most likely.
I had the same problem and a new main board fixed it. Make sure to cut the thermistor connection from pin 2 if you are updating from an old style board to a new style board. If you don't the fridge will not get cold but the freezer will. (Guess how I know)
Posted on Jan 22, 2009
    President:
  • 878 Answers
Misty, if you put in a new fan motor you should have been able to see if the evaporator is frosted up. If it's one big chunk of ice, you have a defrost problem. Usually the heaters are the culprit. You can check it at the main board in back by using on jumper wire on the blue harness. Jump line to defr. This will send 120V directly to the heater. If the heater comes on, you have a board problem. Im assuming that the new fan you put in is working. If they don't come on, the heaters are probably the culprit. part number for the board is wr55x10174. If it's the heaters, part number wr51x10055. Catriver
Posted on Sep 29, 2007
  • Ron Marek
    Ron Marek Sep 29, 2007
    Sounds like the main board is your problem..Catriver.
SOURCE:
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
if it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Nov 19, 2013 | KitchenAid Superba Architect KSCS25INSS...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have an Amana (ABB2524DES) bottom freezer fridge. The fridge is not cooling but the freezer seems fine. I just took the back cover off and the fan is working. I cleaned everything and put it back...
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 30, 2011 | Amana ABB2524DE Bottom Freezer...
I have some problem with my AMANA BX20ML Model REFIGERATOR
You may have a bad condensor fan motor or paper may have gotten pulled under the fridge and jammed the fan blade. The energy switch will not help with cooling it only controls exterior moisture.
Feb 16, 2010 | Refrigerators
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Top Freezer works fine but there is no ice building up in freezer the bottom fridge not cooling properlyThings are not as cold as they should be
Remove the back panel from the freezer to verify no ice behind the freezer panel. Look inside the air vent on the freezer panel for ice buildup. Make sure the freezer control is set to minimum not coldest freezer.. Make sure the freezer fan motor is working.
May 28, 2009 | Electrolux Refrigerators
Freezer is cold but bottom of refrigerator is not
Replace the fan - it's called the evaporator fan. It circulates cold air evenly in the freezer and blows cold air into the refrigerator section. Its failure would cause the symptoms you describe. Good luck with the repair.
Jan 10, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
191 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
