Question about Garmin StreetPilot i3 GPS Receiver
Garmin ggp 300
The screen is blank (back show map arrows are shown) with the garmin in the on mode and none of the operatios working and the system will not turn off or reset.
    Problem Solver:
  • 10 Answers
Have you taken out the batteries? what happens if you installe them again?
Posted on Oct 04, 2007
Garmin receives sat signal ok will give directions - basically everything operates normally with the exception that the actual map on the screen does not show anything.
Go to your settings and check what options have been selected. You may have to revert to the default settings and then tweak your preferences.
Sep 20, 2016 | Garmin nuvi GPS
I have no Maps when I turn on the Garmin, there is a blue arrow and thats all, no back ground at all
The map may be unselected. To select it;
  • Press TOOLS (The spanner icon on the right bottom of the page that shows WHERE TO and VIEW MAP)
  • Press SETTINGS or LOCALE on models that don't have a SETTINGS icon
  • Press MAPS
  • At the bottom of the screen press MAP INFO
This takes you to a screen that shows whatever maps are on the satnav. If there's not a tick beside the map name the map is unselected. Press on the map name and it will become selected. This should solve your problem.
Feb 02, 2011 | Garmin nuvi 1300 Car GPS Receiver
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
Reloading map Screen blank
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 04, 2010 | Garmin nuvi 1300 Car GPS Receiver
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
My garmin nuvi 255W does not show street level detail when just driving around town. how do i change the zoom level so it shows streets and not just a 50 mile (i'm guessing) radius zooom level?
Hi
You just need to touch + or - to zoom in or out. Also the manual for your model is available from this link and describes all operations on the unit. http://www8.garmin.com/manuals/2675_OwnersManual.pdf
Hope this helps. Don't forget to rate my answer. Many Thanks.
Jul 07, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 350 can't see maps after update
Did you contact Garmin tech support? They are pretty good at it.
Mar 30, 2017 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 300 - SD problem
I believe your current location is somewhere in UK/Ireland, which means the Nuvi's last/current satellite fix is not anywhere within Spain/Portugal. If you need to use the maps features of that country where you're not physically there with the Nuvi, the Nuvi must be in Simulation mode first. Fold down the antenna to switch off GPS (not device) and enter Simulation mode.
Then, scroll the map screen (combinations of zooming out, browsing, and zooming in to the spot) until you find the location you want to simulate (it must be within the maps coverage). Then, tap 'Set Loc' at the bottom of the screen. At this point, as far as the Nuvi is concerned, this is the GPS location where you are at. Then you may proceed with Address Search, etc. using the other map's database.
Jul 26, 2008 | Garmin Nuvi 660 GPS Receiver
Updated to 2008 maps, now I lost my local roads and town maps
Turn on the Garmin. Look for the little wrench on the screen and select it. Now look for Map, select Map. Now look for Map Detail. Verify that it is set to "Normal" or Higher to get more map details.
Dec 30, 2007 | Garmin StreetPilot c550 GPS Receiver
Did you try zooming either "in" or "out" ??? Did you verify that the new maps are installed? Did you try doing a reset?
Dec 29, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot i3 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
