Question about Toshiba 46HM95 46" HDTV
We have sound, but no picture
A week ago I went to turn on the tv and the screen was blank. The cable box and the tv were on and I could hear the sound, but the screen was blank. When the tv is off the green and the red light are blinking. Please help. Thank you
  • 1 more comment
  • nutkx Sep 29, 2007
    I just went to turn on the tv again. The screen is still blank, but now there is no sound. Also when you turn on the tv, after a few moments it will shut off then on again. It will keep doing this until I turn off the tv myself and then no lights are flashing anymore.
  • Anonymous Nov 05, 2007
    I'm having the exact same problem.
  • bgw610 Dec 31, 2007
    I have the same problem. Has anyone posted a solution that has resolved this problem?
If you replace the lamp and still have no video, the problem could be the ballast. Replacement cost is similar to that of replacing the lamp.
Posted on Feb 05, 2008
You need a new lamp. I ordered mine through ebay for $155 including shipping, where Toshiba's website wanted $199.
Posted on Feb 04, 2008
    Sergeant:
    Champion:
  • 346 Answers
Could be the relay transistor or diode close to the relay in the power supply
Posted on Dec 28, 2007
SOURCE:
My TV has no sound. The picture is perfect,DVR and cable box are ok. The only thing different is I added a sound bar a few weeks ago when the sound went out on it. I disconnected it thinking the audio...
there could be a number of things effecting it.
check that your TV is not set to only go to the sound bar. This is like plugging headphones in your phone......the tv is probably still seeing the sound bar and the only way you want to hear sound.
try plugging headphone into it and see if they work through that
Mar 11, 2016 | Televison & Video
TV screen is blank but the program is still playing
Check the cables, makes sure all connections are still snug. If your using HDMI, try swapping it out for one you know works. There are a lot of lemons out there.
Feb 24, 2016 | Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My panasonic plasma TV screen will light up, but no picture shows.
Have you tried replacing the cable? They can cause all sorts of trouble.
Oct 19, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Sound but no picture
this happened to me about a week ago. It was my cable box. If you have a cable box,unplug it from the electrical socket Wait about 30 seconds and plug it back in. give the box time to gather all info and then retry the tv.
Jan 21, 2014 | Vizio P50HDTV20A 50 in. Plasma HDTV
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
Toshiba 46HM95 46" HDTV Logo
328 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
