Ah Yes! the old bird in the dryer vent problem!
I would say you are correct. The thermo-fuse blew because of not enough air flow through the heat tunnel.
You probably have a nest in your vent line now.
Clear the entire line from machine outward, replace flex hose if needed and get a new outlet cover with the flaper door on it.
I avoid the ones with screens on the outlet, because it catches lint.
Except in severe cases where a mouse or some other varmit has figure out how to lift the door.
Thanks CCR Repair for the quick response... Will clean the flex hose out, put in a new outlet cover and replace the fuse...
