Question about Mitsubishi WD52527 52" Projection HDTV
Different kind of blinky light problem
Here's a real head scratcher........ I've got a WD-52527 LCD. I got home and had a yellow blinking status light. I checked the filter cover and it's all good. I unplugged the set overnight and it comes up fine in the morning. But it won't come on a couple of hours later. I unplug/replug the set and wait the 70 seconds or so. When I push the power button I get a blinking yellow status light AND a blinking green lamp light. I cannot find what this code means anywhere. I tried getting the code through using the Device/Menu buttons but I don't get consistant codes. One time I got 56 another I just got a 4. Sorry for such the long post. I'm really frustrated. I hope someone smarter than me can figure this out.
  • nichoji Apr 10, 2008
    UPDATE:
    I looked for loose connections and couldn't find any. I took it in and they had to take apart the light engine reseat and resolder all the connections internal to the engine/shutter. I had recently moved the TV across town and that's probably what caused my problem. Works great now with no problems.
  • albert77 May 28, 2008
    my t.v has the same problem the status light just keeps blinking and t.v does not go on.
I have the same problem and found thecode in a service manual. 56 is Shutter Not Connected. I found another individual who said they took it too a shop and they repaired loose conections. I am going to tear into mine to see what it takes to repair it. I will keep you posted.
Posted on Apr 10, 2008
    Genius:
  • 1,153 Answers
Codes are here, and at ctechnicians.com for more info.
Posted on Dec 21, 2007
SOURCE:
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
I have a mitsubishi WD-52527 TV with error code 45
You have to pull the light engine to get to the pbs fan it is the one located closest to the lense on the light engine. you should be able to see if the fan is turning without removing the engine.
Sep 06, 2009 | Televison & Video
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD 52527
I finally broke down and took it to the shop. They said they think I had some loose connections internal to the engine. They reset all the the connections and resoldered the joints. Seems to be woking okay so far. The fix cost me $310.
Oct 28, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 52" Projection HDTV Logo
223 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
