Question about Compaq Presario 5000 PC Desktop
Network Connection I recently signed up for DSL from MediaCom. I had Bellsouth dialup previously. Can't get the DSL to work on my desktop - works fine on the laptop with no problems. The Local Area Connection in the "Network Connections" screen says "Acquiring Network Address" and won't change. I've been all through the support staff at MediaCom but they have no idea what to do. I've checked every parameter, every setting - compared them to the laptop, and still no joy. I'm at wit's end on this one. The dialup still works, there is a 1394 connection that is "connected", and the light on the network adapter blinks like crazy. Still no connection. My desktop is actually a Compaq Presario SR1620NX.
    President:
  • 2,961 Answers
First open up internet explorer and click tools>internet options>connections and the text should be greyed out or select never dial a connection as your old dial up will be trying to connect instead of the dsl line. If you are using a router you need to get in the settings and make sure DHCP is enabled. Go to the local area connection again and to your network card properties and ensure that the TCP/IP properties are set at obtain an ip address automatically. You dont say you are using a router or whether you are wireless or just connecting two pc's together to connect to the net
Posted on Sep 29, 2007
    Guru:
  • 120 Answers
First off, the 1394 connection is a firewire connetion. Firewire is a less popular and slower alternative to USB 2.0 connections. Disregard that in respect to your internet connection. Now in regards to your desktop internet connection.... -Go to the control panel, select network connections, then local area connection. -Right click and select properties -Under the general tab scroll down to Internet protocal (tcp/ip) Make sure the settings are set to automatically obtain an IP address. If they are and still are not working you can try to manually assign an IP address yourself. The laptops ip address might be something like 192.168.1.2 so whatever your laptop ip address is make the desktop 1 number higher in the last field (192.168.1.3 for example). Don't change any numbers other than the last field. You can find out the other information like subnet mask and default gateway by using the laptop. On the laptop go to the start menu, hit run. Then type in cmd, this will bring up a dos prompt. Then finally type IPCONFIG . Listed will be the laptops active internet connections and it's IP addresses. Copy over the subnet mask IP address and the default gateway address into the desktop and like in the previous step just manually assign the desktop a different IP address 1 number higher than the laptop. If the dns server's address isn't listed on the laptop a quick call to your dsl provider will solve that question.
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
I'm trying to connect dsl directly to my laptop - but when I connect the eithernet cable from the dsl modem to my laptop it says there is no internet connection??? The dsl cable works fine with my...
Maybe the laptop is configured by default to look for a wireless signal through its wifi drivers, or a different previously installed modem. Go to your Computer/Control Panel/Network Sharing Center and set up a new connection there so your computer knows what to do.
Nov 02, 2010 | Dell (0E828) for Latitude C610 Modem
I have a second line for dial up and would like to switch over to dsl through my cable company to save some money can I drop my second line (dial up) and go to cable without any problems. I pay MSN direct...
DSL connection works on the same line provided by company who provides DSL. If dialup line is not provided by DSL company, you can drop dialup line and contact DSL company for DSL connection. If dialup line is provided by DSL company, migrate your internet plan from dialup to DSL by contacting DSL company.
May 30, 2010 | Computers & Internet
CAN'T GET TO CHANGE DIALUP SETTING
To make sure settings are not set up to dial go to internet options and click on connections and make sure nothing is in that box. If there is something delete it. Once you check this go to network connections in control panel and make sure there are no dial up connections. If any just delete it. Hope this helps.
May 06, 2010 | Dell Dimension 3000 PC Desktop
When trying to use Outlook Express 6, I get an "Error Message " stating "an error occured while establishing the dail up network connection AOL Dailer"
If you are using DialUp Internet Service from AOL, try establishing a connection first and the open Outlook Express.
If you have broadband (cable/dsl) internet service from another company, then your computer is incorrectly setup. In this case, open Control Panel, Internet Options, then click on the connections tab and delete all and any listed dialup connections or simply select the "Never dial a connection" option right under the dialup connections list box.
Also, if you are not using the AOL software, I'd recommend that you uninstall it completely to free lots of resources and speed up your computer as a result. For this, go into the Control Panel, add/remove programs and remove all AOL applications from the list.
Feb 14, 2010 | Computers & Internet
DSL-2640U connect to internet but want to setup second dialup connection from pc
Sounds like you have high speed internet and also want a dialup connection as well. Maybe as a backup.
Anyway, your pc will need have a dialup modem installed in it.
If you already have one installed then you will also need a dialup ISP account. Some times an ISP will provide dialup in addition to broadband. Ask you ISP or call AOL.
Sep 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a used compacq 530 but do not know what is missing because i cannot get it to hook up to the internet
Possibly if you gave more information .....does it have a network card installed, is the network card "enabled" in the hardware settings, does the network card have correct drivers ? ( no yellow question mark beside it ) Do you have an internet provider and account ? Is your internet high speed or dialup, if it is dialup, do you have a modem installed - with correct drivers ? Is it working - do a modem query to see if it responds ?
If using a network card and cable or DSL internet, is the cable connected from the PC to the cable or dsl modem ? Is the cable or dsl modem plugged in and the power and wan light on ? With the little bit of information you have given, it is not really possible to give an exact answer to what the problem is.
Aug 30, 2009 | HP Compaq d530 SFF PC Desktop
Laptop not connectiong to wireless network
Connect the Laptop to the router with ethernet cable
Verify the wireless LAN
  • Open a browser and type http://gateway.2wire.net; the Home page opens.
  • Click the Home Network tab.
  • Verify the wireless status located on the right panel (Status at a Glance) is Disabled.
  • When the status is disabled, then enable the wireless LAN .
May 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says 192.168.0.1 if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to http://hippo.colorado.edu/info/ipsetup/staticip_setup.cgi?os=win98 for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Compaq Presario 5000 PC Desktop Logo
156 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
